Posted
I detest those VVT engines, all those extra components for what? They can get 400hp out of a snowmobile engine less than a litre displacement so it's not performance
Posted
I get it but if it works and doesn't fail then I am OK with it.  I think with the VVT this makes a flat torque curve from like 2000-3000rpm can't remember.
Posted
Still gotta tie up wires but built a 942 amp hour lifepo4 batterybamk for my house.
About half the cost of lead acid.
  • Like 10
  • Confused 1
Posted
20 hours ago, new guy said:
Hunting for a 1 piece to replace my 2 piece thing a jig...
If you have a Borg Warner there or some other still available Company there are probably drive yokes available. I wanted to use a NP435 in a Dodge Ramcharger with a Dana 70 RE from a Dodge Diesel 250 and I wanted to use the shortened  large U-joint driveshaft.  A 4X4 place in Wisconsin, had the correct shaft size, spline count and U-joint size I wanted.  They also had a new reverse idler gear for the NP435.
Posted
Meritor differential in my Freightliner. Little bigger than they used in the Dodge Ramcharger.
Loud bang, no go anywhere...
  • Sad 2
Posted
Looks like a few different power hop situations getting it out of a field! Lol
Posted
Did that to a heavy haul truck at work last year. Taking off from a light, let the clutch out, loud pop and no go. Found the pieces had rust in the break, mechanic was happy that it happened close to the shop and only had a 35K load on it.
Posted
This 2001 GMC 2500 HD 8.1L is getting a new rear differential carrier, the owner supplied a new one, looks like it might be a cone type posi, the original is the governor type, it doesn’t work, those governor types can be ok but when they fall and a guy wants to upgrade I think a non governor type is the way to go
IMG_3368.thumb.jpeg.842bfda1f21cccd4cd8e0cff54a9a0df.jpegIMG_3369.thumb.jpeg.a0bca6ce4e550f30946927bdc1ce772a.jpeg
  • Like 9
Posted
That the same as the Dmax ones, they had a big ring gear.
Posted
Not since I have been driving it but who knows what the previous owners have done. It has had a crack for a long time evidently judging by the rusty area in the lower left of the pic. Just glad it popped at the farm and not pulling up on to the scale at the elevator...
Posted
Finally got this book.  So I'm going to be working on it for the next few days.
  • Like 9
Posted
Mostly been working on lures for my upcoming trip but had to change the leaking oil cooler lines in my 2000 GMC 6.0 before the trip. Took a couple days and much head scratching but got it done. Chevy “retrofitted” older trucks with newer model oil lines which were shaped differently.  So the lines I got from Napa didn’t look the same. I then called the dealership and they had a set on hand based on my VIN #.
Ok, had to drive an hour to Missoula anyways so stopped in. They looked just like the set from Napa but $110 more expensive. Man, this won’t work!  Well the parts guy was pretty helpful and was able to dig up the notes on the part. Chevy decided to change the line shape to match the newer model and it fits.
How the **** does it go in there I asked?
 Don’t know but this is it. Better YouTube it.
So after 6 YouTube videos I finally found the one that showed how to do it. The set of lines have a block that bolts to the rear of the motor by the pan. Runs to the front and then attaches to the side of the radiator. Wish I had taken a couple pics.
Take the tire off and the inner fender. Had it up on a lift. Then unbolt the motor mount. Take off the power steering lines. Jack up one side of the motor to separate the motor mount. Snake the cooler lines through the wires from front to back and then slide through the open motor mount. And it fit. Job done, just grease up to my shoulders but no more seepage.
  • Like 8
Posted
whoa that sounds like one of my adventures, nothing the same, no instruction, my wallet/budget makes me try to do things myself and low/behold what i thot would be an hour or two of work turns into two days and a lot of frustration.
thank god for youtube/google and people that share their grief and hardship trying to make things work and save $$ like us - I have yet to have teh confidence to tear into something so large as splitting a tractor
Posted
The transmission oil cooler lines on my older Ford truck were in terrible shape. They were all bent up from years of driving in fields and I had brazed several holes over the years. I just ordered a box of rubber cooler lines from Jeg’s. I ran them how I thought they should be run. $50 for 25 feet and no ridiculous line routing.
  • Like 5
Posted
1 hour ago, billonthefarm said:
Wrapped up the cam shaft replacement today.  Ready to go back to work.
Nice!!!!!! Giddy up ole girl!!!
Posted
Hopefully the lines at least last! I have had very poor luck with aftermarket cooler and power steering lines lasting. I've been buying crimp on compression fittings and using hydraulic hose instead. Most times I don't even have to remove the steel line off the vehicle which sure saves alot of time and extra work. Just cut it where it's accessible and slide the new one on and done
Posted
That was my thought with buying the OEM part. Hopefully it will last.
Posted
Time for new clutch pack in my son's bike, then later in the day, they found a way to break this part of the grinder. How, I don't know, they found a way obviously. A bit of welding, good as new
Now, to figure out why the turbo on the td-8 is blowing oil out the pipe. Always something
Mark
  • Like 6
Posted
On 12/6/2024 at 5:16 AM, New Englander said:
I don't know anything about that engine but wouldn't decking the block be a better fix for low liner protrusion?
Years ago it was common in 3010 and 4010 diesel jd to have shims under liner flange to set protrusion. I believe shims are available for most major engines to shim liners if block is worn.
