yellowrosefarm Posted January 25, 2025 Posted January 25, 2025 12 minutes ago, IHKeith said: I thought it was a Mac at first but the print on the handles looked different. The oldest Matco box I have seen, cool to see something new, hahaha I have the matching side cabinet on it too, which the snapon man found later and saved for me. 1 Quote
stronger800 Posted January 25, 2025 Posted January 25, 2025 how old would mine be? SnapOn section on top Quote
IHKeith Posted January 25, 2025 Posted January 25, 2025 1 hour ago, stronger800 said: how old would mine be? SnapOn section on top Your's is the style of Mac similar to Yellowrose's that I was thinking of I'm not versed in dating them but I'd guess it's from the 70s Quote
stronger800 Posted January 25, 2025 Posted January 25, 2025 I thought so too probably. I was able to buy the spring/slider/drawer latch keepers off the snap on truck a few years ago 1 Quote
New Englander Posted January 25, 2025 Posted January 25, 2025 On 1/24/2025 at 10:58 AM, yellowrosefarm said: I bought this dynaglo heater because it was only 20 bucks and supposedly worked. It had a mud dauber nest in one tube and the thermocouple wire was broken in one. After that was fixed it works great. Like a portable wood stove to sit in front of. If I had known how much heat they put off, I would have bought one years ago. I've got a Mr. Heater version with 3 burners. I can get the hangar somewhat warm with a propane torpedo but the heat will blow right out. The infrared is great if you're working in one spot although if it's very cold it'll ice up a 20 or even a 30lb tank. The same with the torpedo so I have to have the tank slightly in the hot stream. I keep my eye out for a 40lb at the transfer station; that's where I found the 30s and they're easy to get recertified for short money. The retail propane suppliers just tell people their tank is no good. I sometimes will keep a tank in my heated shop and take that to the airport for a somewhat longer run time or just run 2 burners. 1 Quote
forwhldrv Posted January 25, 2025 Posted January 25, 2025 Mornings have been single digits or below the past week I figured it was a good afternoon to clean up the original lights. That came with the 350 to get them back on it this spring I put LED bulbs in them even got a red and white one to fit in the rear light with the original lens over it. A little polishing compound and some elbow grease they cleaned up nicely. I should also mention that the garage was cold so I sat at the kitchen table and did this and the girlfriend even helped and didn’t get upset I was working on tractor parts at the table. 9 Quote
searcyfarms Posted January 26, 2025 Posted January 26, 2025 Had to put new vacuum actuators on my daughteds 06 f150 and a new style vacuum solenoid - new ps pump on cousins 2010 accord - (fyi honda/acura ) use special ps fluid dont put standard in it - hydraulic line blew under steering column at valve body - messy job and not red but all new lines now i was helping a friend - new non oem and non epa compliant carb n filters on ms260 with exhaust mod 7 Quote
IHKeith Posted January 27, 2025 Posted January 27, 2025 Started on this truck a while back, replacing the engine. It has taken longer because of complications and time, just fired up for the first time, it runs. Probably won’t get it done before I have to pull it out to work on Monday morning but I will probably be able to drive it out and back in Monday afternoon to finish it 7 Quote
pms1961 Posted January 27, 2025 Posted January 27, 2025 Drive axle in my 73 Camaro has been making noise for awhile.Took it apart and found a bad pinion bearing.I rebuilt it and changed the 3.23 gears for a set if 3.73's.Posi clutches looked real good so reused them.Car has a healthy small block with a 700R4 auto.The 3.73's should help as the engine was not in its powerband when in overdrive doing about 60-65 mph with the 3.23 gears. 12 Quote
IHKeith Posted January 27, 2025 Posted January 27, 2025 6 minutes ago, pms1961 said: Drive axle in my 73 Camaro has been making noise for awhile.Took it apart and found a bad pinion bearing.I rebuilt it and changed the 3.23 gears for a set if 3.73's.Posi clutches looked real good so reused them.Car has a healthy small block with a 700R4 auto.The 3.73's should help as the engine was not in its powerband when in overdrive doing about 60-65 mph with the 3.23 gears. That's a really cool car!!! Quote
new guy Posted January 27, 2025 Posted January 27, 2025 Local carpet farmer commisioned me to build her a barn for her horses. Tried my hand at timber framing. I need to paint up the frame before adding the wall and roof panels. 8 Quote
searcyfarms Posted January 27, 2025 Posted January 27, 2025 3 minutes ago, new guy said: Local carpet farmer commisioned me to build her a barn for her horses. Tried my hand at timber framing. I need to paint up the frame before adding the wall and roof panels. wow she must have some small horses 6 Quote
new guy Posted January 27, 2025 Posted January 27, 2025 3 minutes ago, searcyfarms said: wow she must have some small horses Yep. She is 2 years old. She has small horses. 4 1 Quote
JaredT Posted January 27, 2025 Posted January 27, 2025 7 hours ago, new guy said: Yep. She is 2 years old. She has small horses. Cheapest horses she'll ever own😁 5 1 Quote
Drysleeves Posted January 27, 2025 Posted January 27, 2025 5 hours ago, JaredT said: Cheapest horses she'll ever own😁 Those horses probably won't even start eating the barn. 2 Quote
IHKeith Posted January 29, 2025 Posted January 29, 2025 Did an oil pan on this Ram today. The engine mount bolts have to be loosened to lift the engine, the frame holes for the bolts are slotted. The driver’s side nut bound up on the bolt, I got it loose enough to lift it but I couldn’t get it to turn back. I tried a shorter extension and then a fresh battery on the cordless impact, then the air impact, compressor kicked on shortly after that, waited and still no luck. Was just about to get the torch but oil cooler lines and ECM are close by, compressor was still running by the time I crawled out, so I went back under and the nut moved. Can never have too many tools!! 2 Quote
stronger800 Posted January 30, 2025 Posted January 30, 2025 Slow going when you only paint one night a week 16 Quote
yellowrosefarm Posted February 2, 2025 Posted February 2, 2025 Finished up the light on the Honda. The small wheels on the front are because I don’t have any paved areas, only gravel 8 Quote
billonthefarm Posted February 2, 2025 Author Posted February 2, 2025 Nice day so I took the square body for a drive. 14 1 Quote
stronger800 Posted February 2, 2025 Posted February 2, 2025 I’m…having a vision…it involves a trailer behind that and a 1456….no…A 1466! 1 Quote
Finney Posted February 3, 2025 Posted February 3, 2025 Rebuilt silage bucket for local dairy. New cutting edge, side cutters and rear wear bars. 13 Quote
pms1961 Posted February 3, 2025 Posted February 3, 2025 4 hours ago, Finney said: Rebuilt silage bucket for local dairy. New cutting edge, side cutters and rear wear bars. You do nice work.Don't see too many Allis Chalmers forklifts around here. Quote
lorenzo Posted February 3, 2025 Posted February 3, 2025 Been removing trees on the edge of one of my fields for several years now . Finally getting close to being finished . As for this stump, if ya know ya know. BTW this part was the tree, its up side down in the photo 9 Quote
yellowrosefarm Posted February 3, 2025 Posted February 3, 2025 1 hour ago, lorenzo said: Been removing trees on the edge of one of my fields for several years now . Finally getting close to being finished . As for this stump, if ya know ya know. BTW this part was the tree, its up side down in the photo Bark looks like hackberry to me, not sure if it grows that far west. Perfect hinge on the takedown. Nice deer stand! 1 Quote
