mark60 Posted August 30 Posted August 30 any tips on killing a yellow jacket nest that i can't see the hole i can only see the 6 inch area ware they go in and out i have used foaming wasp spray early in the am a 1% bug dust ,dawn and water mix,vinegar nothing seems to get rid of them Quote
Dirt_Floor_Poor Posted August 30 Posted August 30 You could try something like Malathion that is available at most hardware stores. It’s an insecticide that is available without an applicators license. I would think it would probably kill them if you got it in the vicinity and mixed it really strong. Spray it with a hand sprayer. If you have an applicators license for a farm, there are much stronger ones available. Quote
SASW6 Posted August 30 Posted August 30 My sister just had that problem she boiled a gallon of water and put a cup of dawn dish soap and pored it in the hole she did it early in the morning she did it 2 days in a row she said she did not get them all the first time. She said they were laying dead all around. Quote
yellowrosefarm Posted August 30 Posted August 30 Pitch dark, a flashlight and a gasoline can 4 1 Quote
lotsaIHCs Posted August 30 Posted August 30 I'd mix up some malathion and water and pour a bucket of it on the nest at night. I used to use diazinon but that was outlawed for residential use over 20 years ago. Or as mentioned, a can of gas. Quote
chevenstein Posted August 30 Posted August 30 I've had luck setting up a hot incandescent work light (500W halogen does the trick) after dark near the entrance then flooding the nest with a garden hose. You'll get a swarm which will flock to the nearest hot thing, the light, then you'll have a nice pile of cooked yellow jackets and a wet hole in the ground. Best to watch from a distance with a folding chair and a fermented beverage of some sort. 1 1 Quote
junkandcattle Posted August 30 Posted August 30 Since I am allergic I would wait until dusk or at least until they settled down. That is if i wasn't down from stings. Get a one gallon gas can full of gas and put in the pickup cab with me. Once I was satisfied with the cab door over the hole I would Crack the door open and give them a good drink. I had to do that 3 or 4 times a year while I was pulling a mower conditioner. I think the disk mower screws them up. I haven't been stung mowing since i got it. 1 1 Quote
Sledgehammer Posted August 31 Posted August 31 I've done gasoline and a match. Most recently I got stung while unknowingly standing on the entrance hole. I went back 2 hours later with a new can of good wasp spray in each hand and went in blazing. Killed the entire nest all at once and not one got away. By the next day some critter had dug up the nest. They aren't heavy enough to set off land mines. Dynamite is really hard to get. Lava isn't readily transportable. It's getting harder and harder to have fun now a days... 1 3 Quote
whweldit Posted August 31 Posted August 31 Wait until dark. Gasoline. Pour down hole and around. Done. Quote
mark60 Posted August 31 Author Posted August 31 i have some tim-bor insecticdal dust coming will try that it's in a hard to get at area i can't see the nest hole due to tree roots if that dos not work i will try gas. thank you for the advice i will let you know how it goes. they are tough little bugs Quote
snoshoe Posted August 31 Posted August 31 1 hour ago, Sledgehammer said: I've done gasoline and a match. Most recently I got stung while unknowingly standing on the entrance hole. I went back 2 hours later with a new can of good wasp spray in each hand and went in blazing. Killed the entire nest all at once and not one got away. By the next day some critter had dug up the nest. They aren't heavy enough to set off land mines. Dynamite is really hard to get. Lava isn't readily transportable. It's getting harder and harder to have fun now a days... You can always mix propane and oxygen then add a spark. 1 Quote
Sledgehammer Posted August 31 Posted August 31 24 minutes ago, snoshoe said: You can always mix propane and oxygen then add a spark. Or acetylene..... 1 Quote
acem Posted August 31 Posted August 31 Gasoline seems to work well even without lighting it off. But if feels good to light em up! Or you could try to get some Weevil Cide (Aluminum Phosphide). It works really good but is hard to get anymore. Takes extra special permits. Kills every living creature. Quote
bitty Posted August 31 Posted August 31 I'd try to set up a big pile of tannerite above the hole .... 2 Quote
vtfireman85 Posted August 31 Posted August 31 I can loan you my niece, she’s mean enough they usually just wave the white flag and surrender when they see her with a shovel. 4 Quote
New Englander Posted August 31 Posted August 31 My roommate hit a nest while mowing the lawn on the house we'd rented. After the tirade of curses in Farsi he filled the hole with gasoline, touched it off and watched with a smile and some beer we had left over from a party. Quote
vtfireman85 Posted August 31 Posted August 31 1 hour ago, New Englander said: My roommate hit a nest while mowing the lawn on the house we'd rented. After the tirade of curses in Farsi he filled the hole with gasoline, touched it off and watched with a smile and some beer we had left over from a party. Those Farsi speakers seem adept at such activities 😂 Quote
oleman Posted August 31 Posted August 31 We have bush-hogged several fence rows and no stings, with open station, I believe it is a combination of the rear exiting low diesel exhaust and the bush-hog moving on down the line. Passive yellow jackets, PROBABLY luck too! Wild honey bees, also no stings either. Wild bee chasers came and captured the wild bees. Quote
cumminstinkerer Posted August 31 Posted August 31 I've used diesel fuel and a propane torch several times, the little buggers seem to really like the exhaust not of an old D7E Cat, really sucks when its a high horse open station, when you're stripping for black dirt for a terrace it opens the holes up then grab the truck with the transfer tank on it and give em good dose and light her up! I've had them suckers will swarm the exhaust pipe, I about bailed off with her still in gear a time or two when they got real nasty Quote
cobfly Posted August 31 Posted August 31 13 hours ago, bitty said: I'd try to set up a big pile of tannerite above the hole .... M-80 Quote
junkandcattle Posted August 31 Posted August 31 1 hour ago, oleman said: We have bush-hogged several fence rows and no stings, with open station, I believe it is a combination of the rear exiting low diesel exhaust and the bush-hog moving on down the line. Passive yellow jackets, PROBABLY luck too! Wild honey bees, also no stings either. Wild bee chasers came and captured the wild bees. Yep. Makes me smile when those swallows just show out of nowhere by the dozens. Quote
cobfly Posted August 31 Posted August 31 1 hour ago, vtfireman85 said: Hard to come by True, I still have a few for emergencies.😁 Quote
yellowrosefarm Posted August 31 Posted August 31 1 hour ago, vtfireman85 said: Hard to come by Not if you live near Pedro's https://www.sobpedro.com/shopping 1 Quote
