Ry Stoltenberg11 Posted November 9, 2025 Posted November 9, 2025 Mowing with the kubota when a loud rattle began. Realized it is my exhaust manifold plate rattling. 1 Quote
hillman Posted November 9, 2025 Posted November 9, 2025 2 hours ago, MT Matt said: I was thinking a 300 utility would be useful but it doesn’t have frame rails now that I’ve looked at some pictures. A neighbor has one sitting in the weeds. I think most guys consider a 300u for the front bolster but the axle is set back and without the frame rails wouldn't match up well with a Super W6 t/a. I still have a Farmall 300 if you keep talking about it I may weaken 😉 1 Quote
searcyfarms Posted November 9, 2025 Posted November 9, 2025 6 hours ago, 560Dennis said: Just finished maintenance on this Toastmaster, I don’t know how old it is but it works . how ironic, i harvested the motor out of one like that i called it the water wheel and put it in another unit i had that is still running. Quote
searcyfarms Posted November 9, 2025 Posted November 9, 2025 5 hours ago, hardtail said: 10 round mag and semi fire i still don't see the problem? bow/arrow at night shhhhhhhhhhhhhhhh be vawy vawy qwiet 3 4 Quote
Alan Dinan Posted November 9, 2025 Posted November 9, 2025 7 hours ago, 560Dennis said: Just finished maintenance on this Toastmaster, I don’t know how old it is but it works . Mom and dad had the same humidifier when I was little. Might still be in the semi trailer since we moved out for the flood of 93. Still have a trailer load of junk from back then!! Need to dig a hole and have a bonfire!! 1 Quote
searcyfarms Posted November 9, 2025 Posted November 9, 2025 Been working on some missing sheet metal for the 706 cab 7 Quote
Alan Dinan Posted November 9, 2025 Posted November 9, 2025 33 minutes ago, searcyfarms said: Been working on some missing sheet metal for the 706 cab I have a rotted out door from my 580 backhoe that could use some tender, loving care when you’re finished with that, Robert!!! lol 😂 It’s looking good!! 1 Quote
ray54 Posted November 9, 2025 Posted November 9, 2025 8 hours ago, 560Dennis said: Went to backyard , saw buck was rubbing his antlers on my wife pride and joy white magnolia. Thunder ! Hurried down to farm,family and home and got some post and 7 foot high fence . I pretty tied driving those 8 foot steel post in. Needed to take a lot of breaks . But got it . thunder , wish I liked venison ,there are nine of them in neighborhood and neighbors of them down the street is feeding them ! But have you tried grain/corn fed venison. I shoot a very nice buck 30 plus years ago. The cleaned hanging weighed was 30 pounds more than the average live weigh of most deer and very fat. Only several years later did I find someone 1/2 mile away was grain feeding deer,😉 so they would be too full to eat ornamental plants in the yard.😂 The same taste difference of grass fed beef to corn fed beef. The only venison my wife ever thought tasted good. Also do not bring her grass fed beef into my wife's kitchen. 6 Quote
cm228 Posted November 9, 2025 Posted November 9, 2025 On 9/12/2025 at 11:22 PM, cm228 said: Waiting on parts for the sprayer. So I started another project on a Jd 455 diesel garden tractor my uncle gave us. He got it as a second mower. He had some problems with it. Wasn’t mowing right, overheating etc…. So he went and got a new garden tractor from the dealership. Jd unfortunately. Brought the tractor home, started looking at it. Fuel leak at the filter housing. Filter elbows held in with some plastic “orings”. Ordered a filter housing and since it was cheap enough a thermostat. I put the new filter housing on. Got the fuel system primed and replaced the thermostat. Started it up no leaks. Drove it to our diesel tank and put fuel in it. Was going to have my youngest run it around the yard for a while but then saw something dripping. Pull it back in the shop. Found coolant leak from around a head bolt. Bolt was broken. So ordered a head gasket and a full set of head bolts. Took it apart today. Thankfully the remaining bolt in the block came out with out a fight. Will start reassembly tomorrow afternoon hopefully. Matt Just realized I never updated this project. Got the head gasket changed and installed a new set of head bolts. Got it all back together and running. Had my youngest son run it around the yard. Told him you don’t need to run it “wide open”. That didn’t last long…. lol. Was watching him drive it around, he comes around the corner of a building cracks the throttle open and come by me about as fast as it will go and yells to me as he passes “ this one is fast!” I had him park it a while later and looked it over, no coolant leaks. Put the mower deck on it and tried that. Seemed to work good. Few day later dad said he saw oil on top of the deck. Found a hydraulic oil leak at the steering valve. One of the lines had cracked. Replaced the line and it’s all good now. Matt 2 Quote
cm228 Posted November 9, 2025 Posted November 9, 2025 Today was busy. Got several projects out of the way. Almost time for Christmas tree wholesale cutting to start. Then it on to retail sales after thanksgiving. Will be busy till mid December. I repaired a drawer for my kitchen this morning. The particle board just couldn’t handle it anymore. Drawer front was still ok. Rebuilt the rest of the drawer out of some good cabinet grade plywood. Then cleaned out a barn full of political promises. After lunch I cleaned up a spot in my pole shed for some lumber that we cut from trees I took out of my yard last spring. Needed the trailer the wood was on for the tree farm so it had to get emptied. Matt 2 Quote
560Dennis Posted November 9, 2025 Posted November 9, 2025 On 11/7/2025 at 1:21 PM, searcyfarms said: Danged cheap junk dehumidifiers motor only good for 42yrs the old sears and roebuck on the right had a txplant a few yrs bk i doubt the asian repl motors go that long Do you use white vinegar to clean tank ,water absorption belt ? Quote
hillman Posted November 9, 2025 Posted November 9, 2025 17 hours ago, MT Matt said: A Super W-4 TA would be a cool tractor! He can keep his SHTA, I’d love to have the super ultra rare SW-4TA… Do I need to bring a trailer next spring if I come to Canada to go fishing? 😂😂 I am working on putting this project out of mind but theres a Super W4 tub laying out there from a partout last week......add a F300, Super W4 trumpet housings,hubs & axles, trans cover,drawbar and steering box and I would be 85% on my way to a SW4 T/A. .....maybe😁 3 Quote
searcyfarms Posted November 9, 2025 Posted November 9, 2025 41 minutes ago, 560Dennis said: Do you use white vinegar to clean tank ,water absorption belt ? mine are DEhumidifiers so just coils/compressors i dont use a humidifier here in the winter it stays pretty moist round here most of the time 1 Quote
MT Matt Posted November 9, 2025 Posted November 9, 2025 23 minutes ago, hillman said: I am working on putting this project out of mind but theres a Super W4 tub laying out there from a partout last week......add a F300, Super W4 trumpet housings,hubs & axles, trans cover,drawbar and steering box and I would be 85% on my way to a SW4 T/A. .....maybe😁 You know you have all of the parts just laying around… calling your name… ”build me, build me… fame and glory!” Did I help any??? 😂😂😂😂 1 1 Quote
560Dennis Posted November 9, 2025 Posted November 9, 2025 2 minutes ago, MT Matt said: You know you have all of the parts just laying around… calling your name… ”build me, build me… fame and glory!” Did I help any??? 😂😂😂😂 Can’t have that! I was told it’s the law ! 1 Quote
hardtail Posted November 9, 2025 Posted November 9, 2025 11 hours ago, cm228 said: Today was busy. Got several projects out of the way. Almost time for Christmas tree wholesale cutting to start. Then it on to retail sales after thanksgiving. Will be busy till mid December. I repaired a drawer for my kitchen this morning. The particle board just couldn’t handle it anymore. Drawer front was still ok. Rebuilt the rest of the drawer out of some good cabinet grade plywood. Then cleaned out a barn full of political promises. After lunch I cleaned up a spot in my pole shed for some lumber that we cut from trees I took out of my yard last spring. Needed the trailer the wood was on for the tree farm so it had to get emptied. Matt I need to spend some time doing the same with the drawers, pure rubbish 1 Quote
hillman Posted November 9, 2025 Posted November 9, 2025 2 hours ago, MT Matt said: You know you have all of the parts just laying around… calling your name… ”build me, build me… fame and glory!” Did I help any??? 😂😂😂😂 Yes, it's now on hold Probably worth a fortune if I built it 1 Quote
yellowrosefarm Posted November 9, 2025 Posted November 9, 2025 I believe the crank seal went on my leaf collector tecumseh. It’s older but I doubt it has 100 hours on it. Seal is only 5$. But it is going to take some time 2 Quote
Rawleigh99 Posted November 11, 2025 Posted November 11, 2025 I spent all Saturday and Sunday on the barn roof replacing screws and sealing them up to stop leaks. My legs and back still hurt! I got about three quarters done. It's amazing how many screws there are on a roof. 10 Quote
searcyfarms Posted November 11, 2025 Posted November 11, 2025 3 hours ago, Rawleigh99 said: I spent all Saturday and Sunday on the barn roof replacing screws and sealing them up to stop leaks. My legs and back still hurt! I got about three quarters done. It's amazing how many screws there are on a roof. whoa thats a lot of work dont fall off 1 Quote
oleman Posted November 11, 2025 Posted November 11, 2025 Last time I helped with a tin roof, we were still using lead-heads, IMO, much better sealing than rubber seals. 1 Quote
Rawleigh99 Posted November 11, 2025 Posted November 11, 2025 These screws were 20 years old and I was surprised how much tightening each one needed. I set my drill driver to reduce setting and went over each one. If they didn't set up firmly or the rubber washer oozed out too much I replaced them. Then I went over each one with a silicone sealer that they use on Warehouse roofs. It's supposed to be good for 20 years, but only time will tell. We had a big rain last night and this morning when I checked none of the buckets had water in them, so that is an improvement. 5 Quote
pms1961 Posted November 12, 2025 Posted November 12, 2025 Cab restoration on my 4230 project tractor. 6 Quote
Gearclash Posted November 12, 2025 Posted November 12, 2025 Waiting for the fields to dry up. Replaced the original pickup cam follower bearings on this baler. 31,700 bales on them. Bearings themselves were fine yet but the OD of the roller was about .090” off of new. 3 Quote
560Dennis Posted November 12, 2025 Posted November 12, 2025 On 11/9/2025 at 6:30 PM, yellowrosefarm said: I believe the crank seal went on my leaf collector tecumseh. It’s older but I doubt it has 100 hours on it. Seal is only 5$. But it is going to take some time That a real nice unit there ! Quote
