stronger800 Posted November 28, 2025 Posted November 28, 2025 I’ve never had one stick, or just stop pumping, other than I had a fuel tank cap fail to vent once and it starved the pump and sucked the filters dry; then something in the pump stuck in the starved position. I called my pump guy right from the field and he said “tap on it”. All I had was my pocket knife, hit it once, fuel shot out and it fired 1 1 Quote
CIHTECH Posted November 28, 2025 Posted November 28, 2025 If you have removed top cover and metering valve is free, quite likely you have a stuck delivery valve. Delivery valve is pretty far in. For the guys that can wait a day or 5, we recommend using Viscosity's Fuel System cleaner, we've had better results with it than Stanadyne for targeting a problem. 1 1 Quote
lorenzo Posted November 28, 2025 Author Posted November 28, 2025 1 hour ago, CIHTECH said: If you have removed top cover and metering valve is free, quite likely you have a stuck delivery valve. Delivery valve is pretty far in. For the guys that can wait a day or 5, we recommend using Viscosity's Fuel System cleaner, we've had better results with it than Stanadyne for targeting a problem. So do you add that to the pump when the top is open? Do you just simply pour it in the fuel tank and wait? whats the procedure? BTW i always use Stanadyne and when i opened up the top of the pump it was perfectly clean inside. 1 Quote
lorenzo Posted January 7 Author Posted January 7 Well today was the day, record high of 67 degrees and the ol gal is back up and running. Not trying to start a fuel additive argument so just remember im just stating what i did . Tractor sat too long between usage, wouldn't start and had no fuel coming from the injector pump. At the advice of a company in Iowa that rebuilds these style pumps the thought was to remove the top cap and pour in some Stanadine, let it sit and try it after a couple weeks so thats what i did. Today was warm so i tried it and it started. 23 Quote
766 Man Posted January 7 Posted January 7 29 minutes ago, lorenzo said: Well today was the day, record high of 67 degrees and the ol gal is back up and running. Not trying to start a fuel additive argument so just remember im just stating what i did . Tractor sat too long between usage, wouldn't start and had no fuel coming from the injector pump. At the advice of a company in Iowa that rebuilds these style pumps the thought was to remove the top cap and pour in some Stanadine, let it sit and try it after a couple weeks so thats what i did. Today was warm so i tried it and it started. Out of curiosity how long did the tractor sit? 1 Quote
lorenzo Posted January 7 Author Posted January 7 5 minutes ago, 766 Man said: Out of curiosity how long did the tractor sit? About a year i guess. Not like me to neglect this kind of thing, im getting forgetful or have too much stuff that doesn’t get used often enough. 1 Quote
Powered by IH Posted January 8 Posted January 8 31 minutes ago, lorenzo said: Not like me to neglect this kind of thing, im getting forgetful or have too much stuff that doesn’t get used often enough. Well, I'm positive there are many members that would take the 560 if you need to declutter 😆 1 Quote
mike newman Posted January 8 Posted January 8 55 minutes ago, lorenzo said: About a year i guess. Not like me to neglect this kind of thing, im getting forgetful or have too much stuff that doesn’t get used often enough. OK Lorenzo....so far so good.. now its running, remember the 'back end ''....(getting forgetful, remember.... ).....any problems there, like loose stools etc...shut her down quick... just a friendly reminder We are all here to help Mike 5 Quote
Powered by IH Posted January 8 Posted January 8 12 minutes ago, mike newman said: remember the 'back end ''....(getting forgetful, remember.... ).....any problems there, like loose stools etc...shut her down quick... You mean to say explosive diarrhea? 3 Quote
hagan Posted January 8 Posted January 8 My 560 finally started a few years ago after we pulled it a couple miles behind the pickup and i had to think it had air in it and finally we got it bled out. But bought a old 806 a few years ago from a guy who put a bunch of starting fulid thru it and i got a used pump from a salvage yard and it ran fine 1 Quote
lorenzo Posted January 8 Author Posted January 8 12 hours ago, mike newman said: OK Lorenzo....so far so good.. now its running, remember the 'back end ''....(getting forgetful, remember.... ).....any problems there, like loose stools etc...shut her down quick... just a friendly reminder We are all here to help Mike Your so right it scares me. Not only loose but add unannounced to that. 5 Quote
lorenzo Posted January 8 Author Posted January 8 12 hours ago, Powered by IH said: Well, I'm positive there are many members that would take the 560 if you need to declutter 😆 Well mine just confirmed the long standing dreadful reputation of hard starting so i would hate to have any of you graciously inherit my 560 just to have the rear end fly out the back the following day. 6 Quote
sandhiller Posted January 8 Posted January 8 1 hour ago, lorenzo said: Well mine just confirmed the long standing dreadful reputation of hard starting so i would hate to have any of you graciously inherit my 560 just to have the rear end fly out the back the following day. Well, if your beautiful 560 ever launches it's rear end into Sarpy County😜 I have a donor for you that outlasted it's motor😉 1 Quote
TeachersPet1066 Posted January 8 Posted January 8 15 hours ago, lorenzo said: At the advice of a company in Iowa that rebuilds these style pumps the thought was to remove the top cap and pour in some Stanadine, let it sit and try it after a couple weeks so thats what i did. Our local diesel shop always told us to use Stanadyne so we always have. Glad to hear it is running again. 1 Quote
mader656 Posted January 8 Posted January 8 Now. Take it for coffee (or a drive) on the 5th of every month so it gets used monthly. 3 1 Quote
lorenzo Posted January 8 Author Posted January 8 5 hours ago, mader656 said: Now. Take it for coffee (or a drive) on the 5th of every month so it gets used monthly. I drove it around for two hours and then one of my sisters showed up and she drove it around another half hour then i let it run while i gave it a good bath. It got filled with fresh diesel and another bottle of magic potion. 6 Quote
DT Fan Posted January 9 Posted January 9 I put Standyne fuel conditioner in all my diesel fuel. Put it right in the barrel before they filled it last time. Never seen the stuff with the purple label. 2 Quote
Farmall1066 Posted January 9 Posted January 9 23 hours ago, sandhiller said: have a donor for you that outlasted it's motor😉 That just means the rear end is hanging on by a thread! 🤣 On 1/8/2026 at 7:18 AM, lorenzo said: Well mine just confirmed the long standing dreadful reputation of hard starting so i would hate to have any of you graciously inherit my 560 just to have the rear end fly out the back the following day. Whoever inherits it probably wouldn’t get it to that point, they’d take the shifter to the knee and be laid up for a few days. 🫣🤣 1 Quote
searcyfarms Posted January 9 Posted January 9 yippee...............glad you got it going - i use the bio kleen, i use the newest p/s family stuff called clear diesel also for added elixir, been using them for a few years hopefully have as good of luck with it as I do with sta-bil on gasser stuff so far so good 2 Quote
