Made my own cabinet pulls for the man room. Should be one of a kind.
  • Like 11
..a very '' inviting  ''  picture, Todd....You should have many happy hours ''messing'' with   Firearms and other items of interest ,at that bench...
Those 12 gauge door handles and that Marlin  Firearms  plaque , just set the decor off  perfectly.....
Feel free to stop back by any time Mike.  Bring a 38-55 shell or two and I'll make something from that. 😊
Please tell me the primers have been shortened to hide a screw and are not live.
Be careful what you wish for......Todd....!!!!!!!!
They are perfectly live. I see no issue with live 209's. They pose more danger than spent 209's but only if you are really handy with a hammer and punch.  I even used a carbide burr on the inside of the primer pocket so the cabinet screws would set in there correctly.
I mean it. You are welcome back any time.
......reinstated the very small skid site, after finished logging...couple weeks gone...Battery in camera went flat so few pics
...Removing the big ''shovelling'' grapple is a mission...as it is affixed direct on the dipper arm....oil lines to plug/big swivel pin to hammer out and it is heavy.....then I managed to put the bucket ram , on upside down...and that is bloody heavy, also, hence the 5 ton 'Yanmar'  to hold up the ram , whilst we spun it 180 degrees....(..this was the preferred option, to learning a new, involved ,shift pattern....:mellow: )
Picture of our old Hi-Lux  (Toyota )  with the car trailer  (!!!)    shifting another heavy object...the root rake, down to the logging block for the clean up....
The old bloke with the perished follicles is me....having a ''tool box meeting " and a cuppa, down at ourIMG_2932.thumb.JPG.fd4ddcd77199485ef603b024b947e1d0.JPG local wharf...
On the back ground hills , was the last of ''our''  logging operations...
  • Like 12
Looks like you are enjoying the view. Good for you my friend!
Pulled the pto out & bolted the hitch on. Going to have to make some new threaded rods. The hitch isn’t designed with 520x85x42” in mind.IMG_5275.thumb.jpeg.3bc1133b506ccb2c64e44dfa2d14aa8e.jpeg
  • Like 8
Hooked the blade on the 756 D., then backed it into a tree, it moves! Worked it back and forth a bit, still stiff but getting better. Changed the zerk but doesn't want to take grease, yet. That blade is going to need a lot of love, starting with a new cutting edge and lots of new bolts.
Edit; also got the tires on the 78 Allis hayrake. One step closer to doing something with it.
  • Like 8
Finished servicing the NH 1495 swather today. The hydraulic filter came in and I dumped the oil out of the hydro system. Spent a day pulling shields to grease everything and check gearboxes. Followed the book to find everything.
Finished the tow hitch after a run to Missoula to find a new coupler. Last thing tomorrow is safety chains. Might get a little rain tomorrow night so Saturday I will put it in a field next to the house and see what happens.
  • Like 10
June 4th, dropped a windmill and replaced with solar
Cows hammered it relentlessly, not sure it would ever get ahead of them
Checked it today...........Full Tank Success!
As a side note I built those portable panels the year I got married
That means they are nearing their 40th Welding Anniversary.............🤔🙄😉🤣
  • Like 10
The "free" air-compressor is almost finished and ready to bolt to the floor. Not exactly free, have about $400-450 in getting it back in fighting shape. Saw a new one like it at Northern this week, $1600.
  • Like 9
We’ve been working on this 68 Oldsmobile F-85.  New tires and replacing all the suspension bushings, ball joints, tie rods, idler arm, centre link and shocks.  We ended up having to pull the headers to access the lower control arm bolts, had to lift the engine and remove the starter to get them out.  A terminal broke on the solenoid but we were able to get a new solenoid for $30.  Josh has done most of the work himself, I did the control bushings and the risky parts with the coil springs.  He’s done well, handled it better than when he started in the trade 2 years ago.
IMG_5273.thumb.jpeg.76bf939b7ff806eacda1478e3fbb2c19.jpegIMG_5276.thumb.jpeg.9a4be475426cc13e1483306bdac56f0c.jpegIMG_5274.thumb.jpeg.cc0e95c238a3543e20a576fbfd714994.jpegIMG_5275.thumb.jpeg.eee8ef3b62095ee12e67f37e765a9dbe.jpegIMG_5268.thumb.jpeg.66c496e2776f2b5b8a138373cbb4cd06.jpegIMG_5264.thumb.jpeg.f4f0dc846166bc8282a6e20529195f32.jpeg
  • Like 7
Trying to fix the round baler after I made an 'uh oh!'
Anyone know where I can find one of these new flexible hyd cylinders??IMG_20260618_221006494_HDR.thumb.jpg.696a99c2365e60e59a8404c89075bbf5.jpg
  • Sad 8
I have never seen those newfangled flexible cylinders, must be an engineering marvel🙃
  • Haha 2
OUCH!!
Surplus hydraulics might have one.  More than likely the flexible type is special order!
They make them in Kansas also, but darn hard to find a new one!
