AngrySailor Posted August 11, 2025 Author Posted August 11, 2025 29 minutes ago, jeeper61 said: Looking good!! Been hot up there? 29 minutes ago, jeeper61 said: Looking good!! Been hot up there? Thanks! She’s all together (the blower), drive snout is on, gear oil in. Working on the camshaft end play set up rn then I can bolt the intake down, have some machining to do on the setback plate then top her off with the blower. it’s stinking hot and humid here today. 98f, good day to have the shop doors closed and the AC on… 3 Quote
iowaboy1965 Posted August 12, 2025 Posted August 12, 2025 Wow! I wouldn't have thought it ever got that hot up your way! Quote
AngrySailor Posted August 12, 2025 Author Posted August 12, 2025 32 minutes ago, iowaboy1965 said: Wow! I wouldn't have thought it ever got that hot up your way! July and august we get some hot weather. Usually not this humid. It’s nasty again today. Working in the shop with the AC cranked. Modified the blow off valve on the manifold to clear the distributor, intake manifold sealed up and bolted down, camshaft end play set, lifter installed. We’re setting up to pressure test the core on the aftercooler rn, while pops does that I’ll finish machining the set back plate then I can bolt the blower all down to stay (until I nuke something and have to pull it apart…). 3 Quote
AngrySailor Posted August 12, 2025 Author Posted August 12, 2025 Blower, set back plate done and all bolted down. Cold snack time. 7 Quote
560Dennis Posted August 13, 2025 Posted August 13, 2025 1 hour ago, AngrySailor said: The eagle has landed. Up the Cuyahoga River to Shooters in the hot set up ! A 2 Quote
jeeper61 Posted August 15, 2025 Posted August 15, 2025 On 8/13/2025 at 4:58 PM, AngrySailor said: The eagle has landed. Looking Sharp!! You fire it yet? Quote
AngrySailor Posted August 15, 2025 Author Posted August 15, 2025 13 hours ago, jeeper61 said: Looking Sharp!! You fire it yet? Not yet. Fuel system and final set up on the valve train she’s pretty much ready to fire. Need a few water lines and oil lines, make a set of spark plug wires… hoping to fire it next few days at least once before I go back to work. 2 Quote
560Dennis Posted August 15, 2025 Posted August 15, 2025 How many spreakers in your shop ? Angry ! Quote
AngrySailor Posted August 15, 2025 Author Posted August 15, 2025 26 minutes ago, 560Dennis said: How many spreakers in your shop ? Angry ! That’s all of them! The amplifiers are all out of closed clubs and bars, my friend was a sound guy so I got them cheap. Think there’s 7600w of power as it’s hooked up rn. I can blow a 40a breaker if I crank it up… working on a fuel tank so I can fire this bad boy… need argon ffs. 1 2 Quote
560Dennis Posted August 15, 2025 Posted August 15, 2025 2 hours ago, AngrySailor said: That’s all of them! The amplifiers are all out of closed clubs and bars, my friend was a sound guy so I got them cheap. Think there’s 7600w of power as it’s hooked up rn. I can blow a 40a breaker if I crank it up… working on a fuel tank so I can fire this bad boy… need argon ffs. Thunder ! Quote
iowaboy1965 Posted August 16, 2025 Posted August 16, 2025 19 hours ago, 560Dennis said: Thunder ! Probably sounds like it! 🤣 Quote
TN Hillbilly Posted August 22, 2025 Posted August 22, 2025 23 hours ago, AngrySailor said: That thing's goin airborn... 3 Quote
AngrySailor Posted August 22, 2025 Author Posted August 22, 2025 55 minutes ago, TN Hillbilly said: That thing's goin airborn... Well hopefully only a little bit! Here’s a similar build… he get a little daylight under things here and there… 🤣 3 Quote
AngrySailor Posted August 25, 2025 Author Posted August 25, 2025 Buddy on the ship is messing around with chatGTP. Think I’ll have to have a few of these shirts made up 🤣 4 Quote
nepoweshiekfarmalls Posted September 9, 2025 Posted September 9, 2025 Sounds healthy, Sailor! I am used to seeing engines bolted to outboard motors, so this looks different with the drives on the rear and the bell housing in the front. 😃 1 Quote
Ian Beale Posted September 10, 2025 Posted September 10, 2025 On 8/25/2025 at 4:17 PM, AngrySailor said: Buddy on the ship is messing around with chatGTP. Think I’ll have to have a few of these shirts made up 🤣 "Cubic inches and cubic money" IIRC 1 Quote
560Dennis Posted September 14, 2025 Posted September 14, 2025 Water hose ! sounds good to me and 1 Quote
AngrySailor Posted September 14, 2025 Author Posted September 14, 2025 On 9/8/2025 at 12:23 PM, jeeper61 said: You back sailing the Great Lakes? Yep got three weeks to go then home! On 9/9/2025 at 12:54 PM, nepoweshiekfarmalls said: Sounds healthy, Sailor! I am used to seeing engines bolted to outboard motors, so this looks different with the drives on the rear and the bell housing in the front. 😃 Thanks! Didn’t get to run it much but she’s pretty darn rowdy! It’s a V drive boat so the driveshaft runs forward to the V drive between the seats then back out to the prop. True inboard, prop and rudder. found this today, figured you guys might want to see… 4 Quote
