Posted
So I’d like to have a valve spring bench tester for setting up big block heads. I could get by with using a more common 600lb tester and doing some math but it would be nice to read directly, I’m running over 800lbs open on the nasty stuff. The old RIMAC 600lbs testers are expensive used still and almost $1400 new (branded RIMAC but they’re  hongkoidial knock offs), They’re also reading in 5lb increments. There’s a proform (China) tester for $830 but it’s 700lb capacity and has reviews stating repeatability and other issues. I don’t really need another project but I’m thinking about building one from an arbor press with a 1000lb load cell and a DRO which should be quite accurate. Total parts from crapazon is under $400… it’s still china stuff but I think I could tailor it to my needs…  maaaan I need to sell some engines to fund this addiction… actually scored three BBC blocks for peanuts the other day. Two 454’s and a 396. Bare blocks one 454 was prepped 0.030” over but has surface rust. The others are std.  might look into cost effective top end kits and put together a street friendly/muscle car build to have in stock with a for sale sign on it
Posted
On 12/13/2025 at 1:57 PM, AngrySailor said:
You jinx’d me Dennis. Now we got a cracked liner in the main engine… just pulled the head, hoping it was just o-rings leaking cooling water but the liner has an obvious crack…IMG_5474.thumb.jpeg.60c9c708b25cef326cf5fc3512fb3b18.jpeg
Jinxie ! Guess no tour for me ! Ever!
Posted
We’ll be back around your area sometime! We’re at the Goderich salt mine right now. They don’t have any salt… maybe we’re in the wrong place 🤣 who would possibly think you could get salt at a salt mine??? Here’s the junk liner we pulled out, sending it ashore for scrap.
Posted
Put it in a John deer 🦌 G , that crush those m s at pulling! You can do it if anybody can
? why would you go to a port to pick up salt when they don’t have any 🤔 what did miss?
Posted
They don’t have enough stockpile of finished salt to load us. They’re mining, processing and  hoisting salt to the surface rn and loading us bit by bit. Also they load transport trucks here for road salt and as strange as it seems they take priority over the ships. Gotta rebuild an oil pump for the generator engines, might start that tonight. I already pressed in new bushings just gotta log the measurements and assemble for a spare now.
Posted
Wouldn't want that rolling around in rough waters, good to offload it ASAP
Posted
How's the weather out there, same as your handle?
Posted
2 hours ago, Gearclash said:
I take it the main engine is a uniflow 2 stroke design?  Seems like the inlet ports in the sleeve are quite low  . . .
It is, it has hydraulically actuated exhaust valves with air spring closing, variable valve timing. The ports are that low because the stroke is 8 feet…
Pretty nasty. Better today than yesterday but still gross…
Posted
Posted
Glad you got  into safer water. Shiver Me Timbers break.
Posted
all I know about this from nation weather service yesterday I think
Posted
Obviously the EU needs to get more chick's into the trucking industry
  • Haha 4
Posted
Just got an email from the company… I applied for a scholarship to get my 2nd class Engineering license and was accepted 👌🏻 Not sure when I start but potentially early January. I’ll have to move half way across the country for 8 months. It’s gonna be crazy but well worthwhile.
  • Like 6
Posted
Congratulations Sailor!!
