yellowrosefarm Posted October 22 Posted October 22 I guess you use what you've got. https://www.govdeals.com/en/asset/7/25004 2 4 Quote
Chester5732 Posted October 22 Posted October 22 It’s custom.  Cost 3 times as much as cast due to the copper in it. 3 4 Quote
Sledgehammer Posted October 22 Posted October 22 Failed attempt at converting to 3 phase 😊 2 4 Quote
IHKIWI Posted October 22 Posted October 22 Hybrid prototype.....escaped from Hinsdale back in the day .....last seen as a test mule at Toyota R+D division 🤣 3 3 Quote
Board Shortener Tom Posted October 22 Posted October 22 This is something I would have done (and probably would do today, if needed). I had a trans cooler spring a leak on a 91 Dodge W250 with a Cummins in it. I had a large, aluminum refrigeration condensor that I mounted in front of the radiator support. Had to cut the center of the grill out. It was ugly but it worked well. 😅 3 Quote
12_Guy Posted October 22 Posted October 22 Homebrew Electrall? Just never had time to finish the belt drive setup? 2 Quote
Rawleigh99 Posted October 23 Posted October 23 The motor might be worth more than the tractor. 2 Quote
DT Fan Posted October 24 Posted October 24 Pretty sure I've got one, or possibly two of those in the old garage! Might have to find a 404 to mount one on? 1 Quote
BoilerRed Posted October 24 Posted October 24 On 10/21/2026 at 9:34 PM, vtfireman85 said: Run what ya brung. Yup. Dad crammed the front weight box on the 656 full of window counterweights that he saved when we remodeled the old farm house. Not pretty, but effective. 1 Quote
supermechanic Posted October 24 Posted October 24 Was a guy down the way from my place who had a cast steam boiler chained to the brush guard on the front, it was a David Brown with some sort of a home-brew brush cutter on the back, ugly as all. Quote
dale560 Posted October 24 Posted October 24 Dad had an old steel mayrath auger with a 10 hp Briggs engine. It would over center when raised up so he fashioned an old 100 lb wheel weight mount when that wasn’t enough he hung a motor like that off the weight. Quote
Nehemiah Woolley Posted October 24 Posted October 24 On 10/21/2026 at 9:06 PM, yellowrosefarm said: I guess you use what you've got. https://www.govdeals.com/en/asset/7/25004 If it works it works. It'll be good enough Quote
yellowrosefarm Posted October 25 Author Posted October 25  10 hours ago, BoilerRed said: Yup. Dad crammed the front weight box on the 656 full of window counterweights that he saved when we remodeled the old farm house. Not pretty, but effective. All those good drag anchors going to waste😀 Around here we use them for drift fishing in the river on a flat bottom jon boat. It's enough to slow you down, but they usually don't hang up and stop the boat altogether. 1 Quote
vtfireman85 Posted October 25 Posted October 25 1 hour ago, yellowrosefarm said:  All those good drag anchors going to waste😀 Around here we use them for drift fishing in the river on a flat bottom jon boat. It's enough to slow you down, but they usually don't hang up and stop the boat altogether. Dad used 3-4 of them on the bottom of his chimney brush. His was on a rope, so the weight was necessary. 1 Quote
