Chester5732
Everything posted by Chester5732
  1. Chester5732
    VW/IH update
    If they weren’t electric or hybrid I would be interested. Why not a VW diesel?
  2. Not sure how much a freezer would shrink them. It works for dry sleeves in an M.
  3. I have also seen people put a tire chain on the lift wheel.
  4. Actually, after Farmall1066 posted I found it in my contacts. 😞
  5. If you call your local Napa store they should be able to tell you.
  6. You could sleep in that one.
  7. It sounds like you live an interesting life!!😄
  8. There is a fella in Iowa that does gauge repair too but I can’t remember who it is. I talked to him once now I can’t find his contact info. 😞
  9. Peaceful Creek should have them.
  10. I just ignore the crap. Total waste.
  11. Never heard of them but curious to see the responses. I called the fella in Florida one time but with his broken English and my poor hearing I couldn’t understand much he said.
  12. Mine weren’t born yet.
  13. Congrats and good luck!!
  14. That happened to a good friend of mine just over 2 years ago. Went for a motorcycle ride and never made it home. 33 years old and a month old baby at home. RIP Mike.
  15. Thanks for the warning. I have never heard of that let alone experience it. I have passed out from dehydration but that turned out ok. Now when it gets hot I am as much of a hermit as possible.
  16. Part of the reason I don’t own the truck. I drive someone else’s.
  17. But a couple gallons of gas is still cheaper than an ER visit for heat stroke.
  18. I think your on to me🤣
  19. I’ll be right there with you later today. For my baby’s 21st birthday we are going on a pedal trolley. This broken down old man with two types of arthritis and worn out artificial knees pedaling a trolley just to go for a joy ride? Good thing there will be 14 other people!😁
  20. Yes. The 5.9 from the sprayer is getting tucked in a corner and I may buy the adapter plate now just so I have it.
  21. Yup. There are retrofit options if it comes to that.
  22. Sounds like the whole assembly for both valves might be available. Will find out for sure. Thank you.
  23. Learned a lot about the 5.9 Cummins in this thread but it looks like I won’t need to do a conversion since I just bought the 826.
  24. So I bought this 826 with a single rear remote. I found a fella with the parts off from a 1466 to make it dual remotes. Will the parts interchange?
  25. No. Gear drive. Factory T/A delete. I need to get the goods to add a second hydraulic outlet and a 3 point control lever. Someone broke the end off.
