pt756 Posted May 12 Posted May 12 Good evening, another question, was thinking about how to make a 3 point skid steer set up so I could just back right into the skid steer buckets or bale fork, pallet forks, looking for some idea, would be handy for collecting round bales into an area for loading, I wonder if there are old skid steer hook ups around? I am capable of welding the parts on to make it a 3 point, thanks Quote
vtfireman85 Posted May 12 Posted May 12 The parts are readily available, geometry of hooking up might prove challenging as rolling out to grab the attachment would be impractical. 1 Quote
stronger800 Posted May 12 Posted May 12 What he said. You roll out or tilt out to hook a bucket on a skidsteer then roll back to latch it, instinctively without thinking. Your three pt arms can’t do that , Quote
Farmall1066 Posted May 12 Posted May 12 4 hours ago, acem said: Would probably need a hydraulic top link to make it work. That’s where my brain went right away Quote
yellowrosefarm Posted May 12 Posted May 12 I welded one of these I bought off of Clist to a flat skid steer plate. It's not very useful as is, because not every implement I have is the right spacing to fit it. I've been thinking that using a solid rod with "dog bone" plates could overcome that, but haven't got around to trying it yet. Quote
brahamfireman Posted May 12 Posted May 12 Putting skid loader attachments on a 3 point is going 8 steps backwards. Just use the skid loader...... 1 Quote
vtfireman85 Posted May 12 Posted May 12 2 hours ago, brahamfireman said: Putting skid loader attachments on a 3 point is going 8 steps backwards. Just use the skid loader...... I can’t speak for him, but there’s a lot of my property I can’t get on with the SS much of the year because it’s muddy, the tractor I manage to. 1 Quote
JaredT Posted May 12 Posted May 12 11 minutes ago, edwardporter1 said: Tracks =$50k plus, just saying Quote
pt756 Posted May 13 Author Posted May 13 Did plan on using a hydraulic cylinder, was thinking more for picking up bales in fields farther away, our skid steer is only a 130 bobcat single speed, Quote
acem Posted May 13 Posted May 13 Many of my friends and neighbors have smaller tractors that use the skid steer attachment on their front end loader for bucket, spear, forks, etc. 1 Quote
vtfireman85 Posted May 13 Posted May 13 30 minutes ago, acem said: Many of my friends and neighbors have smaller tractors that use the skid steer attachment on their front end loader for bucket, spear, forks, etc. I can use the SS attachments on the Kubota, I don’t go the other way mostly because the SS attachments are much more heavy built, but for large lightweight loads the SS bucket on the Kubota is the shiz. Quote
brahamfireman Posted May 13 Posted May 13 15 hours ago, vtfireman85 said: I can’t speak for him, but there’s a lot of my property I can’t get on with the SS much of the year because it’s muddy, the tractor I manage to. You must have way different dirt because here a tracked skid steer will go anywhere but a bog. A wheel tractor will sink in anything that looks even moist. My original statement was aimed at the fact that any skid attachment now becomes virtually useless on a 3 point. Let's use a bucket as an example, no down pressure so you can't cut into anything hard, and no ability to scoop/ dump. Grapples, you can't lift a 3 point more than 24"off the ground so what is a guy going to do, push sticks around? Forks, again can't lift high enough to do anything other that move a pallet from A to B. Bale spear, they sell 3 point spears all day so why modify a skid steer one just to move bales? 1 1 Quote
lorenzo Posted May 13 Posted May 13 On 5/12/2026 at 6:59 AM, yellowrosefarm said: I welded one of these I bought off of Clist to a flat skid steer plate. It's not very useful as is, because not every implement I have is the right spacing to fit it. I've been thinking that using a solid rod with "dog bone" plates could overcome that, but haven't got around to trying it yet. I have one of those welded to a skid steer plate for sale Quote
TroyDairy Posted May 13 Posted May 13 Imho BobTach is waybover used. It was designed 60 years ago and perfect for 45hp gas Bobcats. Now we got em on 120hp mfd tractors. We know many whom have lost loads since Tach let bucket loose etc since was tweeked a little from simply too much hp pushing around it. I see your thought on 3pt hook up. But i think with the availability of 3pt bales spears and pallet forks it would be wiser to just buy those at a auction and go. Your not stacking in a warehouse you just want to move things. Dont you have a loader tractor too? 4 Quote
vtfireman85 Posted May 13 Posted May 13 59 minutes ago, brahamfireman said: You must have way different dirt because here a tracked skid steer will go anywhere but a bog. A wheel tractor will sink in anything that looks even moist. My original statement was aimed at the fact that any skid attachment now becomes virtually useless on a 3 point. Let's use a bucket as an example, no down pressure so you can't cut into anything hard, and no ability to scoop/ dump. Grapples, you can't lift a 3 point more than 24"off the ground so what is a guy going to do, push sticks around? Forks, again can't lift high enough to do anything other that move a pallet from A to B. Bale spear, they sell 3 point spears all day so why modify a skid steer one just to move bales? Cool for you, but I don’t have a CTL, and I don’t have the budget to replace the SS with one either, I have clay soil, it doesn’t drain and it turns to slime the instant you break the sod. While USS attachments on a 3 point seem awkward for some applications I completely get trying to use what he already has. Quote
acem Posted May 13 Posted May 13 Skid steers don't work in the mud at my place. Not enough ground clearance. 2 Quote
yellowrosefarm Posted May 13 Posted May 13 2 hours ago, acem said: Skid steers don't work in the mud at my place. Not enough ground clearance. When I see that picture, I can't believe what you have is actually working. Quote
Ihfan4life Posted May 13 Posted May 13 5 hours ago, vtfireman85 said: Cool for you, but I don’t have a CTL, and I don’t have the budget to replace the SS with one either, I have clay soil, it doesn’t drain and it turns to slime the instant you break the sod. While USS attachments on a 3 point seem awkward for some applications I completely get trying to use what he already has. Seth…. I have just what you need to go where you want to. a Horse…. Bring a trailer🤩 1 Quote
brahamfireman Posted May 14 Posted May 14 11 hours ago, vtfireman85 said: Cool for you, but I don’t have a CTL, and I don’t have the budget to replace the SS with one either, I have clay soil, it doesn’t drain and it turns to slime the instant you break the sod. While USS attachments on a 3 point seem awkward for some applications I completely get trying to use what he already has. I still don't understand what you’re doing in the mud with a tractor and you need a bobcat attachment on the tractor? Like what is the task at hand? Quote
