2 hours ago, TN Hillbilly said:
Trying to fix the round baler after I made an 'uh oh!'
Anyone know where I can find one of these new flexible hyd cylinders??IMG_20260618_221006494_HDR.thumb.jpg.696a99c2365e60e59a8404c89075bbf5.jpg
How did that happen?
2 hours ago, IHKeith said:
We’ve been working on this 68 Oldsmobile F-85.  New tires and replacing all the suspension bushings, ball joints, tie rods, idler arm, centre link and shocks.  We ended up having to pull the headers to access the lower control arm bolts, had to lift the engine and remove the starter to get them out.  A terminal broke on the solenoid but we were able to get a new solenoid for $30.  Josh has done most of the work himself, I did the control bushings and the risky parts with the coil springs.  He’s done well, handled it better than when he started in the trade 2 years ago.
IMG_5273.thumb.jpeg.76bf939b7ff806eacda1478e3fbb2c19.jpegIMG_5276.thumb.jpeg.9a4be475426cc13e1483306bdac56f0c.jpegIMG_5274.thumb.jpeg.cc0e95c238a3543e20a576fbfd714994.jpegIMG_5275.thumb.jpeg.eee8ef3b62095ee12e67f37e765a9dbe.jpegIMG_5268.thumb.jpeg.66c496e2776f2b5b8a138373cbb4cd06.jpegIMG_5264.thumb.jpeg.f4f0dc846166bc8282a6e20529195f32.jpeg
I had a 62 F-85 with the 215 Aluminum block V8.  They sure improved the looks by 68. This one is going to drive like new with all that suspension work.
I really enjoy jobs like this on newer cars and classics. Not all of them get as many new parts as the Oldsmobile, but whatever they need.  Making sure that every alignment adjustment is free to move like butter.  On a car like this F-85 the bolts that hold the upper control arm and the shims to adjust camber/caster can be corroded, depleted threads etc.  Having it all apart and clean, new shims, new bolts makes it so easy to adjust.  Most of the time I stack a generous amount of varying thickness of shims and simply have to pull a couple out.  Shims come in 1/64,32,16,8 inch sizes so you can imagine if you are fighting a corroded, dirty frame/shim/bolt/control arm rod, you’re going to chase your tail a bit.  Same thing with a cam bolt or tie rod end, if it doesn’t move like butter then it’s not going to turn out the best.
I have been doing alignments since 2007, in Eastern Ontario, where salted roads exist over half the year.  I know a few tricks to overcome seized adjustments when the situation is right, a happy medium that will keep tires and drive well when budget and vehicle condition is low.  When the vehicle is of good condition like this Oldsmobile and needs this attention, nothing but the best will do.  Can’t skimp on a single detail and the end product will always satisfy.
In a bit deeper now. .30 & .20 over. March of 83 date.IMG_0568.thumb.jpeg.c5be0d7f4ef4323d73b9a4f01af9d039.jpegIMG_0567.thumb.jpeg.4aabfa346b540560ebdc4d85f6bfde09.jpeg
  • Sad 2
Replacing the radiator in my daughter's car. It has a cracked tank and leaking. Can't complain too much, it is 20 years old and has 216k miles on it. I bought it for $500 about 5 or 6 years ago with a broken timing belt. Replaced the belt and all of the valves and it was good to go. I'm working next to my 1066 just to keep it IH related!
  • Like 8
It's amazing how a rubber hose will stick to something after 20 years! Finally got the old radiator out but man did those transmission cooler hoses stick! Ready for the new radiator. If you look REAL close you can see a tiny crack next to the mounting boss for the cooling fan. It's pretty evident in the picture but with the radiator in the car it was hard to see. I had to use my pressure tester to find it.
Shortly I will be kicking a 1984 ih 4 cylinder 685 which UK dvla saying it has a 4599 cc diesel having the fuel lift pump on the RHS, with the siamezed 2 port exhaust manifold ( no lid on top of exhaust pipe for past 24 years ), the haudraulic pump is on this side on back of timing chest, and the fuel filters, inj pump and *fire in inlet manifold* are on the lhs with the starter motor.
Could anyone help with info please on this engine and transmission, parts exploded views would be wonderfull.
Going round in circles getting info, I need your help .
All info greatly recieved...thanks
And it is in! Still have to connect the upper radiator hose and bleed the system but on the downward slope. Yes, this was a Chinesium radiator, but so is the OE one. OE, where I used to work was $244, this was $65. The $65 radiator I put in my wife's car about 3 years ago is performing just fine. A racoon took hers out.
Some confusion. IH 685 was built in Doncastor England. Had a 3.9L engine. Hydraulic pump was on left side behind transmission.  Are you sure of the model number?
Thanks for the reply.
The pictures I was sent seem to have gone AWOL, waitng for some more from carol, hopefully recieved before I go down south...
Both rear window regulators on my Yukon went out on the same day a couple of weeks ago. What are the odds of that? So after a delivery from RockAuto, I put the new ones in this evening, along with 2 new speakers.  Old ones were blown and I was right there anyway.
  • Like 6
Today’s the day got my weld coding test this morning no pressure let’s hope I can keep a steady hand
its been really manic of late on the construction side with the excavators then first time out with the small baler yesterday to kick off the season then along came the biggest thunder storm we have had in a long time that will slow that job for a min perhaps give me chance to breath
also got a tractor pull and dyno day coming up in Aug so I have booked in the magnum at least a little fun to look forward to
  • Sad 1
Hope the test goes/went well. Hang in there.
All done not ideal in the middle of a heat wave I think I have melted but got it done all good so far will be awaiting results once back from testing 🤞
1 hour ago, Board Shortener Tom said:
Wiring an outlet for my air compressor.  I even left the mess everywhere so any visitors would think an actual electrician did the job! 😂😂
Converted the rock picker to hydraulic drive for this season.
Put on the NH3
Did some harrowing
Got the crop seeded
IMG_6247.thumb.jpeg.a08efd01e4ef637b202544ba257c679d.jpegIMG_9383.thumb.png.5886199393dc8600bcb6d5d6975fcc01.png
Picked up a new to us sxs.
Ran a bunch of jobs through the shop.
IMG_6268.thumb.jpeg.c10176327b636b9312d6a8bed7ad0d39.jpegIMG_6269.thumb.jpeg.13a6ad0f9e8cbf5732197ffc374683f3.jpeg
Got the first pass of spraying done.IMG_6184.thumb.jpeg.6ef09e7172fc9b1e5d56897d35a6dd32.jpeg
Got the signage looked after for our local music festival benefit.IMG_6272.thumb.jpeg.8d4e2478f5ecb82e49c6675a99c1ea04.jpeg
Got this bbq gazebo fabricated just in time to take in for the live auction at the Jamboree.
  • Like 12
Put on the NH3
Did some harrowing
Got the crop seeded
You've been busy!
Installed a new alternator on the W6 and installed the hood for (hopefully) the last time.  Wiped all the winter dust off the tractor.   Time to install the decals.  Tractor has a date with the local 4th of July parade next week.
  • Like 6
Good day baling today just a bit hot not so bad in the right direction to scoop in a bit of air also the boys keen to drive so I can find a shaded tree for a break all I got to do now is educate him to maintain and repair and I can retireIMG_0067.thumb.jpeg.f9b90a42f517802e8e6233e52af38ab5.jpegIMG_0066.thumb.jpeg.a6c53680ef94ccc20ed231d0a21b62c6.jpeg
  • Like 9
Replacing the timbers under a hayrack today.
  • Like 8
I think you coulda got another year lol
  • Haha 2
