Rawleigh99
  1. Ours would only shock for a short predetermined time before it shut off, so if the dog ran through the containment it wouldn't continue to be shocked. I assume if the power went off it would be a similar situation. Ours also would not shock on the way back in. A continuous shock would be terrible for the dog though.
  2. That paint job is probably way better than the factory one even with the bugs!! Looks good.
  3. We used to use one at our old house. It worked pretty well. I was sort of like a wireless computer router. You plugged the base unit in and the perimeter was where the signal ran out. You had to go around with the collar first and mark the perimeter as it will vary by house size, shape and building material. Overall pretty good and I would do it again if I did not have a fenced in back yard.
  4. You can never have too many, right!!! LOL
  5. I'm going to be the outlier here. I have a harbor freight titanium 200 amp 120/240ultiprocess welder that I have been very satisfied with. I have had several other welders including an Airco bumblebee (rebadged Miller Dial Arc) that I still own. This little multi-process welder is light enough to pick up and carry around with one hand and will do everything I needed to, including the lighting 6011 rods. I currently have it set up with 0.035 flux core wire. I find that as long as she remembered to reverse the polarity for the flux core wire, it works very well. If I were willing something structural I would go back to rod however. For $599 on sale you can't beat it.
  6. Moly Grease will be dark no matter what, since Moly is naturally black.
  7. Wow Dan you have really been busy once again. You sure set the bar high for the rest of us! I love seeing your work. Thanks for sharing it. First class.
  8. Don't do it!!!! Look up tire explosions. The heat can cause the tires to explode minutes to hours later! Very dangerous to heat a rim even if the tire is off the bead. Be safe! Take a die grinder and grind the head of the bolt off. Remove the rim and THEN weld a nut on it. Sorry to be fussy, but we want to keep you around and safe!
  9. Amen Brother!!!
  10. Great news! Congratulations! I knew you could do it! 😀
  11. Just the vapor would knock them dead. No need for fire. Might have been a little hard on the fairway! LOL
  12. When I worked on the golf course as a kid, the groundskeeper used a 16 oz glass Coke bottle filled with gas and an old.wool blanket. He would turn the bottle upside down and stick it in the hole and throw the blanket over it to leep any from escaping.
  13. Yesterday I bored out the cam bearing cavities in two Harley motor cases for the engines a friend is building. The test case was one the factory needle bearing had already spun in so it could be reused The second was a new case so that made me nervous! Did it on the old Bridgeport with a boring head. Seemed to work out okay. No pictures though. I guess it wouldn't matter since we can't post them anyway! LOL
  14. Sledge would be drooling!
  15. I saw that on the news about the guillotine. Maybe they are afraid the peasants are about to revolt! LOL
  16. 1969 Chevy Impala 4 door in Sherman tank green! With a 396 and a TH 400! My mother used to tow the horse trailer with it after adding a hitch, airbags and electric trailer brakes. Very sporty! LOL It was a hand me down. My sister drove it to schools too before me. It threw a timing chain on me out on the interstate on the way home from college about an hour and a half from home. That was fun in the days before cell phones! At least back then no one was afraid to pick up a kid walking down the side of the interstate.
  17. Very sad!
  18. Unfortunately it is creating a patchwork of conflicting laws across the country. You will have to keep all sorts of paperwork to prove you were in the class covered by the injunction and when and how you bought it. What if you want to sell it? Or pass it by Will? In 20 years will your heirs be able to find the paperwork? It is a good start, but a poor place to finish! I just don't want to be on any government lists, although I am probably unwittingly on them anyway.
  19. A very wholesome performer. Not many left like that as a good role model for girls!
  20. We are loosing them all at an alarming rate. only natural at their age though.
  21. Can you spray foam the hole shut???
  22. Put some mice in there! They will cover up the smell.
  23. I have a 1966 931
  24. None anymore here.
