Posted
I’m having some difficulty in trying to determine which male coupling to use?  Not sure if this 1066 has the original style remote couplings or some modification.  Additionally I’ve never noticed a bolt & washer on the backside of the coupling but I’ve never had much difficulty in connecting equipment either so haven’t paid any attention before.  Two photos attached to help explain what I haven’t put clearly into words.
Posted
ISO conversion.
They can be a pain to get hooked up and unhooked. Lots of brute force and awkwardness...
Posted
Put the tractor valves in float before you connect will make it easier
and any pressure on the male tips will make it more difficult
-- lock the machine in transport before disconnecting
-- or be sure  the pressure is off the hoses before disconnecting
-- levers in float will help in both cases
Posted
It surprises me how many people don't know about the float function and/or don't use it, then struggle with their hydraulic couplings...
After the chewing-out I got for not floating the disc before unhooking it, I never forgot to float before unhooking ANYTHING again, ever.
Posted
Those ISO kits were originally offered by IH in 1983 when the 50/30 Series started arriving with those couplers from the factory. I still have a copy or two of the IH instruction pamphlet that was in the non-IH box containing the kit.
Posted
Some tractors have the float  blocked off with the bolt under the lever. Mine all were when I got them.
Posted
Evidently I mislead the participants on this thread - - I wasn’t complaining about the couplings being hard or even easy to connect.  I was just asking about the bolt & washer setup on the rear of the coupler.  Replies point to them being ISO.  That brand is new to me.  I’ve seen factory couplings from tractor manufacturers & Pioneer brand - - but never a brand by ISO.  So now I’ll ask, which brand is preferred - IH, Pioneer or ISO?
Posted
ISO international standards organization.  Not a brand but a standard specification. Most pioneer are ISO and the names are often used interchangeably.
Posted
Bolt and washer is how the coupler is retrofitted to the existing casting. Washer is stepped to fit the housing and the bolt is threaded into the coupler to retain it for use. Rubber grommet keeps most of the dirt out and is retained by a small snap ring appliance. You can either cut a small "v" in the bottom of the grommet to allow oil to drip or drill a hole in the center of the bottom coupler slot and attach a fitting with a drain hose. First couple sets I installed years ago were not in IH packaging but had the IH instruction pamphlet and an IH molded in the rubber seal to occupy the slot where the old lever once lived.
Posted
They have their pluses and minuses.
They accept the iso/pioneer tips that are now pretty much universal.
It's much easier to install the conversion than rebuild the originals.
But they don't last as long for me as the originals.
I like to run one of each on my tractors. Makes it easier to keep track of the hoses.
Posted
I just converted my 806 to the ISO couplings, the reason being that I had just recently bought a 2450 loader that was set up with the ISO tips. I helped the guy that I bought the loader from take it off his Hydro 70, I was impressed at how easy it was to connect and disconnect the hoses. So rather than change the male tips I bought the conversion kit from RedRunRight. It took a little time and a home made bracket from angle Iron to attach them so they didn't interfere with 3pt hitch but Im very happy with the setup now.
Posted
The ring on those couplers are supposed to be inside the aluminum housing -- that allows them to be break away style
some are even push pull style
Posted
You know I wondered about that, they work the way they are but I will change them tomorrow. I had planned on taking that bracket off and welding on a cap and painting  anyway. Thanks Hydro.
Posted
26 minutes ago, acem said:
Converted 806 to ISO tips?
I thought they all came with them???
Mine did
Posted
Yes they all came with ISO factory. The large IH couplings came out with the 66 series tractors.
