HydroTek
6 Followers
    Southern Indiana
HydroTek's Achievements
2.3k
  1. Looks to me like a large hole in the sieve in that picture -- upper part of the picture also at least one row of fingers is missing Yeah and too closed off also too much ground cobs Settings are important to a clean crop and efficient operation that machine can do a great job if you set it
  2. Worn linkage and "speed shifting" remove the floor plate and look under at the linkages also in the console , may get a bar in there to get the linkages back in line Usually the problem in the Hi Lo linkage did not get in neutral before you went into R
  3. Gasser ?? Check the freeze plugs under the valve cover
  4. Crank thrust bearing should control that
  5. Maybe end play -- I was after vertical play
  6. The setup papers that came with the loader is what you are after most of those went in the trash after the loaders were installed -- of if you have put a few on , the papers were not taken out of the plastic -- still hit the trash tho
  7. Main bearings loose ? That is a lot of pulleys in a short time Remove the pulley and get a dial indicator on the shaft put a bolt back in so you can pry up and down on the shaft Would also be a good time to check shaft runout Have a 2188 here on the Farm that got a little warm during bean harvest but may still have some good parts on it
  8. Same bolt pattern and same hole in the center ? you tell us Take a pic so we all can see
  9. Put the alternator on a test stand and see what it puts out -- or rig it up so an electric motor can run it and test it your self would answer a lot of the questions
  10. I suspect that the disk is not sitting flat to the metal surfaces -- tapering the edge of the disk is the fix Also the linkage on that tractor is a little odd -- need to be sure that the linkage is not the whole of the problem -- restricting pedal movement OP indicated that it was a rusty mess , like most of those are
  11. so the pin fits tight in the hole usually the problem is only on the top pin in that coupler -- I suspect the shift rod is not as hard as the lower part of the shifter plenty of those that just have a hose clamp over the worn pin holding it in place also can just drill the hols out and use a spiral roll pin -- or double the pin by driving a smaller pin inside the first one
  12. Glad to hear of your progress The pads need to sit on clean metal -- if there is rust coating the surface , the pads will not grip -- or grip poorly if the pads were too thick , then the brakes would be on all the time -- pretty sure this is not the case the expanding part will move out about 1/4" -- so should be plenty of movement you should get the feel of the brakes at about half way on the pedals -- feel the pedal get tight against the pads the strongest part of the actuator is at the beginning of it's movement if the metal parts are too worn and the actuator needs to move a lot then the force is weaker against the pads leaving the rubber boot out will allow you to see into the housing when the brakes are applied this is when the housing can be milled down some to overcome wear the caution is milling too much and binding the brakes when they are not applied be sure the linkages are able to move fully and pull on the actuator rod enough to make it expand
  13. ... or just get a number 6 taper pin drill the hole out to 5/16 to get rid of the egg
  14. Maybe don't need all that extra effort Can you not just add length to the existing tube to make it longer ? use a hose to join the two tubes together -- will also add a vibration break because of the hose section
  15. Will the tractor pull a load in Lo t/a ?
