I'm sure this has been discussed here and on other forums in the past, but I'm looking for some assurance from some real world experience. Basically, I want to remove the seat and then the top cover of the draft and position control housing and unscrew/remove a tall plug that presumably exists in there. Supposedly the Hytran will then find a level below the leak source (bad o-rings or whatever) and I can go blissfully about my day without losing another gallon of spendy fluid. The alternative would be to remove loader, remove cab, remove loader valves and then the draft/position controls just to replace a couple of o-rings. Not gonna do that. Apparently, the only downside to the plugectomy is there will be a void of fluid in the top of the reservoir so that the parts inside will no longer be bathed in fluid and that water may condensate in said space promoting rust. Also, I'm curious to know if this will affect the dipstick reading. There's probably a couple of you out there that have done this. If you have, I'd sure like to hear from you before I proceed. Thanks in advance!
