RockinRam96 Posted January 20 Posted January 20 Is there anyone out there that makes fast hitch prongs? Just the prongs. To weld onto an implement or replace bent prongs on an existing fast hitch? Looking to replace the prongs on a back blade that got bent up the PO. And to also weld onto a couple attachments that have the larger prongs. Thanks. Quote
DT Fan Posted January 20 Posted January 20 There are a lot that have been removed from plows. See them at auction once in a while. Not aware of any new ones but maybe? 1 Quote
766 Man Posted January 20 Posted January 20 Give a metal shop the pattern and they can cut one for you with a plasma cutter. 1 Quote
naedlaen Posted January 20 Posted January 20 craigslist in Ft Dodge, IA area has several listings. You might check in your area on craigslist. I searched for fast hitch in farm/garden Neal Quote
GaAgTech Posted January 20 Posted January 20 Agri Supply carries them. 20” long as well as 30” long. 2 Quote
RockinRam96 Posted February 13 Author Posted February 13 Just coming across this. Thanks for the info guys. In was thinking about asking a local fab shop if they could cut me some with their plasma table. $94.99 each seems pretty steep from Agri Supply! Quote
Chester5732 Posted February 13 Posted February 13 With the price of metal and their hourly rate I bet Agri Supply is cheaper than a metal shop. 2 Quote
Board Shortener Tom Posted February 13 Posted February 13 Not sure what fast hitch you have but Burch sells new points. https://burchstoretractors.com/collections/newest-products/products/new-farmall-1-point-fast-hitch-prong?_pos=2&_sid=c219541b3&_ss=r Quote
RockinRam96 Posted February 15 Author Posted February 15 On 2/13/2026 at 2:01 PM, Board Shortener Tom said: Not sure what fast hitch you have but Burch sells new points. https://burchstoretractors.com/collections/newest-products/products/new-farmall-1-point-fast-hitch-prong?_pos=2&_sid=c219541b3&_ss=r I have a 2 prong, small on my C. Are the single prongs the same dimensional size as the small dual prongs? Quote
DWV Posted February 15 Posted February 15 From what I remember the single prongs were larger than a C. Same as socket on a 300 ETC. Quote
Matt Kirsch Posted February 15 Posted February 15 Correct. The single prong is the same as the "large" style. Quote
Binderoid Posted February 16 Posted February 16 They are not that precise.... could be done with a torch .... the only thing that really has to be right is the 90⁰ that the latch hooks into. But you can fine tune that with a grinder. 1 Quote
IHRedRyan Posted February 16 Posted February 16 I had these laser cut and the pin bores machined about 5 years ago for our 300 Utility. They fit into the single point receiver on the cub as well, although the single points should have a vertical tang that provides side to side support. Did I understand correctly that you’re looking for the smaller style for a Super C though? 2 Quote
RockinRam96 Posted February 20 Author Posted February 20 On 2/16/2026 at 10:27 AM, IHRedRyan said: I had these laser cut and the pin bores machined about 5 years ago for our 300 Utility. They fit into the single point receiver on the cub as well, although the single points should have a vertical tang that provides side to side support. Did I understand correctly that you’re looking for the smaller style for a Super C though? Yes that is correct. I am looking of the smaller style points for a Super C. Quote
RockinRam96 Posted February 20 Author Posted February 20 I am also looking for the leveling link that adjust the pitch of a fast hitch plow, side to side. It goes from the touch control on the left side back to the float control of the fast hitch, just below the driver platform. Anyone have a line on one? 1 Quote
HydroTek Posted February 20 Posted February 20 Good chance to brush up on your Black Smiting skills ? -- looks like a pretty good pattern in that picture Quote
Jeff-C-IL Posted February 20 Posted February 20 Beginning to suspect you have an interesting resto happening. Pictures are required. 😁 2 Quote
Rainman Posted February 21 Posted February 21 I got a Leveling Link from used equipment jockey in Wautoma, WI. I'll see if i can find his contact info... Quote
Rainman Posted February 21 Posted February 21 Leveling Link....Gene.... Wautoma,WI ....920-787-7635 ..(Info from 2012) Quote
RockinRam96 Posted February 22 Author Posted February 22 On 2/20/2026 at 1:15 PM, Jeff-C-IL said: Beginning to suspect you have an interesting resto happening. Pictures are required. 😁 No real restoration planned. I bought the tractor to work, pull a Cultipacker over my food plots or maybe a flail mower to keep trails clean. Really just wanting to keep it alive. Fix what doesn’t work and maintain to keep it reliable. Bought a fast hitch plow, thinking it would be fun to go to plow days with. Have a line on a trailer plow locally, and a few other implements. Just looking to play with the tractor. I like the Cs. They’re little tractors that do big tractor work. 4 Quote
HydroTek Posted February 22 Posted February 22 We used a Super C with narrow front to jockey machinery around at work Added dual remotes on the rear and had the fast hitch that make hooking to equipment easy 1 Quote
RockinRam96 Posted February 24 Author Posted February 24 They’re cool little tractors. They can do big tractor work, but then put cultivators on them to do little tractor work. Quote
RockinRam96 Posted March 12 Author Posted March 12 Found a complete fast hitch locally. Now have all the pieces needed to plow properly. I will probably use the leveling link as a template, make one myself and sell the hitch as whole. Hopefully get my money back! 2 Quote
