Posted
5 hours ago, jeeper61 said:
Very cool. I see the engine is reversed, which makes sense since the drive is reversed. The early style hydraulic pump must run off the driveshaft. I wonder if they ran a chain drive to the rear wheels. Also wonder how they ran the driveshaft to the transmission since it would normally run off the other end of the engine. Jackshaft below the flywheel end up to the transmission through chain drives maybe? I don’t see a belt from the starter/genny to the engine pulley behind the pto clutch. Maybe just lost in the picture.
Posted
Maybe it’s just a two wheel drive.
Posted
Could be. Just thinkin!
Posted
13 hours ago, jeeper61 said:
@MrMarty51 apparently we were concerned about you hauling your TD14 for nothing😳
  • Haha 4
Posted
13 minutes ago, yellowrosefarm said:
Carefully crafted photo shop?????
Could be
 Don't forget that old saying
"truth is stranger than fiction"
So if you would happen to be trying to offset too much tongue weight you would put the heavy piece on the back
Posted
13 hours ago, Chester5732 said:
Is that kinda like baptizing a cat?  Asking for a friend.
As long as you make sure to hit the power wash button a few times it isn't.
  • Haha 2
