Posted
Looking at the pic didn't make sense but the video did🤣
Posted
Couldn't tell what they set off but it certainly had some explosive force
Posted
14 minutes ago, iowaboy1965 said:
I think it would take longer than 4 days for a pig and a chicken to understand the concept of a trampoline. I might be wrong though because it seems that they can always find the same hole in the fence and get out again, even if you can't😁.
  • Haha 5
Posted
12 hours ago, Chester5732 said:
A discus from the Roman Empire.  Worth 14.7 billion dollars.
I think it's a discus from the Nazi Empire made to make Sherman tanks go boom
  • Sad 1
Posted
27 minutes ago, lorenzo said:
What no clips on the ball hitchs
  • Haha 3
Posted
3 hours ago, lorenzo said:
That is the hitch on an Idaho tote flatbed the wheels are actually a caster and you pull it behind your RV in places where you legally can't pull a second trailer cuz the two balls make it one and then you get that little hoochie there to hook it to your pickup when you want to take the razor or whatever down to the sand dunes from the campsite
Posted
Never seen one.  Can’t tow double anything’s here in NY (other than big rigs).  But I did notice on trip to Chicago around the lake last week that guys had boats and wheelers behind their camper trailers
Posted
Same here in WA.  But in ID its ok.  So there guys invented this unit since it messed them up when traveling to other states. Uncle had a Razr on the back of a 36' 5th wheel.  Talk aboit tail swing!  Aunt would guide him in fuel stops to be sure things were ok way back there. If you're really cool you tow a 30' RV and behind that a Idaho-tote with a SxS on and then a 27' river sled boat behind that down the highway.  Quite the look!
Posted
Found this while I was rewiring the MD. There seems to be a gum wrapper around the light fuse. I guess, you got a do what you got a do😁.
Posted
The corrosion causes heat that melts the fuse. The aluminum foil makes the circuit whole again but will still melt out if circuit is shorted. Got me home many a time over the years.
  • Like 7
