Posted
1 minute ago, nepoweshiekfarmalls said:
Does he still have that 291?
It got transplanted into their 560 that was pretty tired, I think he has the 263 still but not sure, he may have brought it down to you at work. I know where there is a tired but running one, not sure of price, it is complete from fan hub to clutch, I believe the fan is missing, it even still has the alternator on it, it's sitting on a tire in a friends shop, it was removed this spring. If you are interested PM and I can get you guys in touch with each other
Posted
3 minutes ago, cumminstinkerer said:
to correct my post the complete one is a 291
Might be the easiest solution to fix Dad's 706.  Just keep it stock.
Posted
On 12/26/2024 at 7:55 PM, acem said:
I've seen a 706 with a 6BT Cummins (5.9).  A 4BT would probably be good too and different.
How about a V6-71 Detroit?
  A friend has a 706 with a tired D310.  He is looking at putting in a 5.9 Cummins.
Posted
On 12/26/2024 at 1:59 PM, nepoweshiekfarmalls said:
I question whether the 407 would fit under the hood.  I was thinking that the radiator housing and dash supports are shorter on the 706.  Would I need an 826 front casting and 806 dash towers?
I seem to remember that might be the case
I would never put a 4BT in anything unless it has the internal balancer as they are 2,500 just for the balancer. Without it at an idle they will loosen every bolt on the tractor I'm told. I believe that after having a fleet of those engines in xt skidloaders . They are rubber mounted and still try to vibrate everything
Posted
If Aaron doesn't take that 291, I'd be interested.
Posted
My 706 hood/dash is noticeably lower than my 856.
Posted
1 hour ago, acem said:
How about a 7.3 power stroke?
Or 6.0
I wouldn’t suggest a 6.0 to my worst enemy!! Lol
i don’t know if the torque curve on a 7.3 would lend itself well to a tractor, but it would be interesting. Probably easier with an older mechanical engine vs the true powerstroke, though.
Posted
With 225 HP at 3,000 rpm, i wouldn't be too concerned.....
Posted
today I drove by a open station 886, sign said repowered with a 414 and turbo, some day I would like an open station 86 tractor, at least you dont have to worry about fenders and I think they look really sharp
