On the 856, there is dual hydraulics, it is a custom, so some where along the line somebody added the second set of hydraulics, they used rubber hydraulic lines, question would the steel lines be available or are they kept together for dual hydraulics ,
23 minutes ago, stronger800 said:
Actually…aren’t 56 lines rubber?  Look through  LongFarms’ 1456 pics…then you’ll know
Lines from valves to seat supports would be steel. If equipped with breakaways. The lines from seat support or check Valves to couplers are rubber. Without breakaways. The couplers are fastened directly to seat support or check valve.
My 856 Custom had item #57 fail and I was able to get a new one through New Hydraulics in Oshkosh, WI. Mine doesn't have dual system but I assume the dual hydraulic system uses #24 and #31 which they also offer.
Best bet is a scrapyard. Any large frame 56 series will have the same lines.
New, I doubt it. Maybe in 1987 but not in 2026... You could have them made, there's at least one service out there that will make you any line, but I doubt you'll like the price, and you also may need the original lines to copy.
Here is my 1969 856 Custom valves. It was one valve from factory. I added a second valve from salvage yard when I bought tractor in 1987. #1 valve feeds #1 set of couplers. #2 valve feeds #2 set of couplers.
THANKS  for the picture, number 2 is what I would need, still a ways to go on tractor, big need is a set of 16 inch double bevel rims and 18.4 tires, tractor has 15.5 by 38 on now,  judging from how hard it was to get things apart I think they were on there for awhile, nice set of rims with a decent set of tires still in good shape, maybe have to find a tractor to put those on?
8 hours ago, brewcrew said:
When the steel lines fail, we replace them with rubber. I don’t see why you would want to spend more on steel, especially used.
That's what im thinking.
We have a 786 that is now a rubber line down from the block to the coupler. Been that way going towards 20 years now.
For the life of me now I can't remember what happened that damaged it while Dad was drilling wheat but a rubber line got put in in it's place.
Picture from sales brochure of Farmall 856  showing tractor equipped with break-away couplers supplied with rubber hoses from points above, which are double acting check valves bolted to their respective supply points of the hydraulic system.  Custom model would never have been equipped from factory with double acting check valves nor break-away couplers. Custom models have the female aux. coupler bodies mounted directly into blocks ( but not double acting check valve blocks ) as seen in 2nd picture below.  I have seen pictures of tractors that someone added a second valve to it and used rubber hoses directly into the auxiliary valve outlet ports instead of the banjo fitting and steel lines as from factory.
So , you need the number 2 steel line
So , you need the number 2 steel line with banjo fitting in picture below?   Here are some sources... https://www.google.com/search?q=+IH+tracor+part+%23398426+R1&client=firefox-b-1-d&hs=jxPU&sca_esv=f775133c7e6e79d5&ei=GGhWaaT6LsW5qtsPgYmimQI&ved=0ahUKEwik5o-vq-qRAxXFnGoFHYGEKCMQ4dUDCBM&oq=+IH+tracor+part+%23398426+R1&gs_lp=Egxnd3Mtd2l6LXNlcnAiGiBJSCB0cmFjb3IgcGFydCAjMzk4NDI2IFIxMgUQABjvBTIFEAAY7wUyCBAAGIAEGKIEMggQABiiBBiJBUjAvwFQlQlYlKMBcAF4AJABAJgBUKABlwqqAQIyMLgBDMgBAPgBAZgCFaAC9wrCAgsQABiwAxiiBBiJBcICCBAAGLADGO8FwgILEAAYgAQYsAMYogSYAwCIBgGQBgWSBwIyMaAHhUSyBwIyMLgH7QrCBwYwLjkuMTLIBzqACAA&sclient=gws-wiz-serp
Rainman, did look at the website, sure looks like they have most everything covered, Close to Wausau over the years I have been able to go to J and D tube Benders to make those steel lines, they also did nice work, I do need the power steering line for the 1066 that leaked awhile ago, looks like these guys have it ,I have not seen the Dairyland guys advertise, was aware of the other place, did call a couple of times,thanks
We met Dairyland/ Ben @ their display in Spencer, Iowa RPRU 2024
