Calendar
Everything posted by Red Flyer
First off, I have found this thread to be most interesting and informative. I have had this 806D for about five years that I paid $1000.00 for with a stuck engine. After overhauling 2 gas engines. (farmall 230 and farmall M) I decided to tackle a Diesel engine. I call the 806 my trade school tractor because I tore it all apart and did get it running just as a learning project. I do know that one of the liners it not that tight, the clutch is bad as is the T/A. I have a short block from a salvage yard that claims it has 400 hrs since overhaul. The short block is black and a C block. So my first question, are there oversized liners available or do they have to be painted up with aluminum paint? Or should I take a chance on the short block? Also the injector pump and injectors have been overhauled and a new mcv pump has been installed. Thanks in advance of you comments. APF
Like the green in the air intake.
Not hard to do at all. I like to clean up the commutator on a small lathe so it has good contact with the brush. Make sure you have GOOD cables.
Starts filming here again in May for the next season.
Most uncomfortable car I have ever sat in that is 2 yrs old.
I would go for it.
Dad had one. It was a good day when he sold it.
I am trying to install a new muffler and tailpipe on a 1986 F-250. When I got the pipe and muffler I put a magnet on the pipe and muffler to see if it is steel or stainless. The magnet stuck and then I find out that some stainless exhaust pipe will hold a magnet. My original plan was to weld it with a mig welder and not use the clamps that came with the kit. If I do weld it I assume that I will need stainless welding wire and then how do I transition from OEM steel to new stainless pipe. Should I just clamp it and forget about welding it? Should I not worry about it and just weld it. Four pieces that came in the kit will all slip together. Thanks in advance for the comments. Arlin
We put one in 5 years ago for the A/C mostly. When the heat side kicked in it did not do well below 25 deg F.
Stevens Model 67. Must have been the auto correct.
Most of the series is filmed here in the Bitterroot Valley. The barn and ranch house are just south of Darby. Other scenes have been filmed in Hamilton and Missoula and I see the Yellowstone trucks in my town (Stevensville) on occasion . Down side is that it has attracted to many people to the area and real estate prices are just getting stupid. I enjoy watching it as well.
- 65 replies
- 12
Well I certainly do not need another tractor or project for that matter. It would just be added to my collection and sit most of the year. Mostly interested in your comments about the hours. APF
12,922 hrs to be exact.
Glad someone explained that to me.
For what it is worth I got my new top screw and lower housing today. I measured the old top screw and new top screw and the were the same. It appears that only the lower housing stripped out. APF
I was plowing with my 550 5 bottom plow with 2 rounds left go. The left hand leveling screw striped out. In your experience does the screw part strip out or the housing part strip out ?Should I just plan on replacing both halves? Top screw 397 095 R2 housing 396 752 R1. Thanks in advance. APF
Thanks again. I will do my best.
Yes I see that now. Looks like the smoke was coming from under the gear box. Any way to look under the gear box?
I discovered smoke coming from the rear rotor bearing after the rotor bogged down. I can turn the rotor ok but found some burnt chaff inside the rotor cone like it is wrapped around the bearing. I can only get my fingers in there so far. Is there another access to the rear rotor bearing. Thanks in advance. APF
We have a center pivot irrigation system and some Sudan grass showed up in our field in a perfect pie shape. I assume someone dumped the seed into the supply ditch and ended up on our field. Still see some of it in the field 5 years later.
And the off color pistons from a 466 so said Eddie one time.
