Delta Dirt Posted May 29, 2018 Posted May 29, 2018 Welder----- We really need to see the 1210 winch truck pulling the skid steer out. Would you mind "re-staging" that scene for a photo for us. Thanks in advance from everyone here on the RedPower forum!!!?? DD Quote
AKwelder Posted May 31, 2018 Author Posted May 31, 2018 On 5/28/2018 at 7:34 PM, AKwelder said: Well it was sold before I had time to go, and was an hour away. I never made it but the red power mafia may have a lead for me. More to come Sale fell through and they called back, I am going out Friday. Now there is a discussion about a blown head gasket “or something”. Gas motor so that wouldn’t be to bad. But what if it’s more than a head gasket? Oh well, what’s another project? Quote
new guy Posted June 1, 2018 Posted June 1, 2018 You dont HAVE to buy every one you come across!! Thats what my wife says anyway.... I am a poor listener.... Looks like an interesting project worth a closer look. 1 Quote
AKwelder Posted June 2, 2018 Author Posted June 2, 2018 Went out to see the 504 tonight It has a US Corp of engineers tag on the from. It was purchased by the US army in 64 the cab had this tag there is water in the engine oil, but the exhaust cap is missing, no oil in the radiator though. Started up and ran. Throttle was buggered up. The dash wiring was a mess, along with most of the wiring. Tires were new. 1 Quote
poor farmer/logger Posted June 2, 2018 Posted June 2, 2018 So when's the delivery day? Lol. It sure looks like a Russian tractor with that style can on it. Weighted up plenty heavy by the looks of it. Quote
AKwelder Posted June 2, 2018 Author Posted June 2, 2018 2 hours ago, poor farmer/logger said: So when's the delivery day? Lol. It sure looks like a Russian tractor with that style can on it. Weighted up plenty heavy by the looks of it. Yeah, it’s heavy. The plack from the cod of engineers calls the shipping wieght as #7000. And it is odd. No PTO. And the front is louvres that you can close in the winter. It really is pretty rough and has milky oil. But maybe the exhaust cap being off did that? I don’t know. not for two grand is what I am thinking. Only thing it would do is plow snow Quote
hillskinefarms Posted June 3, 2018 Posted June 3, 2018 8 hours ago, AKwelder said: Only thing it would do is plow snow Yeah, but you guys get a lot of snow............ Quote
AKwelder Posted June 8, 2018 Author Posted June 8, 2018 Got some wind the other night. Tree top snapped off and landed on my bees nest gor it sorted out and back together, it should be alright also have plants growing, we upgraded the pump on the irrigation and will be starting to set up irrigation on the new plot Quote
AKwelder Posted June 9, 2018 Author Posted June 9, 2018 Wow. Just got a IH 1100 mower for $400 at auction Quote
AKwelder Posted June 10, 2018 Author Posted June 10, 2018 Brought it home The duct tape was to hold a lose rod in place on the ride home So there is a “A” type frame between the wobble box and the PTO shaft that moves, can anyone tell me what it’s for? It sounds strange, but now I want to make it into a fast hitch 1 Quote
bitty Posted June 10, 2018 Posted June 10, 2018 6 hours ago, AKwelder said: Brought it home The duct tape was to hold a lose rod in place on the ride home So there is a “A” type frame between the wobble box and the PTO shaft that moves, can anyone tell me what it’s for? It sounds strange, but now I want to make it into a fast hitch On the fasthitch ones the pipe clamped for the axle is where the hitch clamps on to be a two point. I will try to get pictures later today Quote
AKwelder Posted June 10, 2018 Author Posted June 10, 2018 3 hours ago, bitty said: On the fasthitch ones the pipe clamped for the axle is where the hitch clamps on to be a two point. I will try to get pictures later today Gotch ya, So if I had a set of points and a bar/shaft it would clamp right to it and then run a cable between the touch control and the lift mechanism then it’s on to the PTO, I really don’t want to cut this shaft down, anyone know of somewhere for the PTO shaft to pulley shaft connection? Quote
Bleedinred Posted June 10, 2018 Posted June 10, 2018 The A frame action will lift the bar more or less parallel to the ground when you get converted over to FH. You'll have to fiddle with the rod/chain length to get the outboard hinge/paralell lift actions correct. Check your bar/hinge bushings, moving the end of the bar by hand front to back. You will want those to be pretty tight. Rowse rakes in Nebraska is your cheapest place for parts. They hold the IH patents now. I think it was $3.50 ea for the steel bushings and $36 for the brass one on the wobble box hinge. You could probably make yourself a drive line, those are fairly light and inexpensive knuckles and crosses, or buy a jobber length, cut it and be done. I've been mowing banks and terraces in our vineyards with my 3 pt. #300. I put a small hyd cylinder in place of the lift rod and and it will lift the bar 90 degrees. 1 Quote
bitty Posted June 11, 2018 Posted June 11, 2018 19 hours ago, AKwelder said: Brought it home The duct tape was to hold a lose rod in place on the ride home So there is a “A” type frame between the wobble box and the PTO shaft that moves, can anyone tell me what it’s for? It sounds strange, but now I want to make it into a fast hitch Here is pictures of my good one (so to speak) and my one that needs more work . I'm not sure which one is which. Lol One I have is incorrect where the pipe clamps to the fastpitch but that one has the pulley and everything to make it operatable as it theoretically did work when I got it. The other has the one pulley missing and a log splitter attached in place of the pulley. A piece of pipe and flame cut the fast hitch prongs out , locate someone to weld it together and Wala you might be in business. I would look at the PTO shaft as it might be able to be cut shorter and look oem 1 Quote
AKwelder Posted June 11, 2018 Author Posted June 11, 2018 Thanks Guys, I need to ponder a bit and take some measurements Quote
AKwelder Posted June 13, 2018 Author Posted June 13, 2018 Drove to Valdez today, summit lake was a bit cold, they had snow over the weekend along the road St Elias in the clouds And the glacier coming over thompson pass Not the the best weather, but a great run 1 Quote
AKwelder Posted June 16, 2018 Author Posted June 16, 2018 One of the guys invited me along to go out and check his shrimp pots yesterday . Pulling up pots from 350 feet Spill response barge 1 Quote
AKwelder Posted June 16, 2018 Author Posted June 16, 2018 FYI. They were great cooked on the grill and dipped in butter and garlic. Wow. So much better when they are fresh Quote
Delta Dirt Posted June 16, 2018 Posted June 16, 2018 Great scenery again Welder------and you made my mouth water talking about the grilled shrimp. Question: out of curosity----- what would the water temp be out there now?? DD Quote
AKwelder Posted June 17, 2018 Author Posted June 17, 2018 8 hours ago, Delta Dirt said: Great scenery again Welder------and you made my mouth water talking about the grilled shrimp. Question: out of curosity----- what would the water temp be out there now?? DD I am not sure how cold, I guess it’s near 40*, there was ice floating in its just a few weeks ago. Quote
AKwelder Posted June 18, 2018 Author Posted June 18, 2018 Headed home from Valdez today. A couple days at home and on to Prudhoe bay Thursday Quote
AKwelder Posted June 20, 2018 Author Posted June 20, 2018 Pictures from the last few days big boats being tied up wet and cloudy ride ho e, and very windy checking the peony field when we got home, they are getting big i head north tomorrow, more pictures 1 1 Quote
AKwelder Posted June 22, 2018 Author Posted June 22, 2018 Trip delayed one day, headed out this morning. Leaving town one of the trail heads lose to town dropping into into the valley near coldfoot And more valley, that’s the Brooks Range ahead And the pipeline huge granite mountain (I think) that always takes a good picture power unit for a remote valve, really neat ORMAT generators keep battery banks charged, antennas for remote control, very cool stuff. Very few moving parts, runs off below ground propane tanks Atigun pass, and a bit chilly still south side North side Someone hualing a Quad Trac south Panorama of the mountains around us as we come out the valley on the north side of the brooks, not sure if you can really see it Snow cats headed south Muck ox on side of road Side dumps on on the road construction, they are raising 60 miles of road nearly 10 foot and almost doubling the width. I have no clue how many yards of gravel Sitting in deaadhorse now, I drove about 500 miles in 12 hours, have a good night 1 Quote
AKwelder Posted June 27, 2018 Author Posted June 27, 2018 Finished the drive home today, was really nice on the slope when i started the run Small Black bear wandering around later I will grab the SD card out of the camera and see what works Quote
AKwelder Posted June 27, 2018 Author Posted June 27, 2018 Here are a few pictures off the camera more of the Blacky A Grizzly on the tundra Caribou jumping in front of me And the Musk Ox that used to be impossible to see Saw a total of 5 bear on this run, not counting the cubs one sow had. And one of the crew had a wolf run past him. about 10 foot away, and big 1 Quote
