Grumpy Gaby
    http://boyd_gatfield@yahoo.com
    Weston, OR.
    Own: 1954 Farmall 300 FH, TA, "Old Red"; 1957 TD-91 w/six way "Hitchhiker"; 1958 350UD FH, TA;1955 International 400D "pre W";
    Extended Family has owned: "More Red than I can remember"
2,484 profile views
Grumpy Gaby's Achievements
  1. Aw Tony! That remark plus the Disnyland remark is what it's all about!!!!! The 91 year old, I'll Bet you made his day for needing those balers, and going to a "Ramos (sp?) restoration" had to be icing on the cake! That is another reason, to see the glow on someone else's face!!! ……… Ifn you really have to get rid of "junk" (also called someone else's pride and joy) you can always load up a load and take into the scraper, maybe get enough to buy a bottle of wine or two.
  2. What a score! But yu know now it will take longer to restore one...…. Cus You'll have to be running from baler to baler making sure you are going to use the best part!!!! What a delima, having three of everything to choose from!!!!! I LOVE IT!!!!! Will be following closely.
  3. Looking GOOD! Tony I'm like Smoker1, If I came down and walked around the baler once, I would walk out the door with at least half your dirt/grease attached to me!!!! Keep up the good work!!
  4. Hadn't heard about the fires, but did hear about your record setting high temp's. Your skeeders will have to start carrying water tanks to keep cool! Are some of these fires going to be put out by the first snow fall?
  5. Well, I didn't find anyone that have been in these SOOO I opened it up! The bottom is held together by 4 (I'll dots, but needed something on the inside to back up) You can see the one on the cap real good, the one that matches it is on the bottom at about 11:00 o-clock I used a pair of vise grips to flatten out the dots. It took a special screw in the end of a slide hammer to get apart.There are three bafels just slid in. The brass rods did not want to come out. (I did not try heat) The upper end of the twisted square rod has a guide on both upper and lower ends. The u shape flat bar is magnetic. The twisted rod is heat treated. There is a button that the twisted rod goes into, and then the button fits into the bottom of the gauge casting. There is no through hole. One the aluminum face plate has a dot in the lower edge to locate it in the top of the casting. The top of the casting also has the dot and the face sets just inside the inner ring that you can see. The needle sets on the solid pin and is turned by the magnet through the casting. The cover is two piece cromed brass. I had to insert a thin tool (pocket knife) between the glass and the rim of the top cover. (parts in this photo are upside down) After lifting the rim a little I went around the outer edge with a very small screw driver and tapped and lifted the top cover, glass, and bottom cover out of the casting. As you can see the glass is very brittle. (glass is 1 7/8 inch in dia. and .13 inch thick. the was what I thought was corrosion under and around the face disc. but the same type of "stuff" was between the cover, glass, bottom cover, and casting. Might have been decomposed sealant or glue. There are brass inserts in the threads, don't know if these were to keep it from coming apart, or to hold the brass rods into the casting. I tried to pry the stirrup down far enough to get the twisted rod out of the hole, as you can see, I didn't succeed! Not going to mess with it until I put it back together. If you need to free up the needle, go into the top. Free up the twisted rod, try to do it with out taking the bottom apart. I am not sure how to put a new cork on, maybe split it and glue it back together. Well that's all I know!!!!!!
  6. Has anyone successfully taken an original apart to rebuild? With some wd40 and just a little heat, I got the top to turn in the cap a bit. It will rotate until the brass stirrup rod comes in contact with the edge of the opening in the bottom of the cap. Does the stirrup have to come out, or does the bottom of the cap come off? ?
  7. OBG I hate to disagree, but the 100 replaced the super A. The one in your picture is a 130, or painted like one. I figure that you know sooo much that you are intitaled one mistake!
  8. Good, I was starting to wonder about your family with these storms going through. Did you have bad roads? Just think..... your own BED!
  9. What did it have it to start with for engine?
  10. More on steering. The hole for the cylinder shaft end was wallowed out badly, so years ago I welded it up and sized for a clearance hole for the shaft. To my supprise, there should be a locating washer in that hole. So now it is like it should be! Moved the steering wheel a little to get the stud in to line up the ball . Put in the parts and move the steering wheel back, put in the stud, nylock, and remember to grease! And ready for hoses. The power steering pump was bad enough that I could not rebuild it with the rebuild parts kit. I ordered one from Steiners, ended up putting it on "OLD RED" because I could never get the stock power steering valves to work, besides the new pump had different connections. I found this pump on E-bay, it was off of a IH truck and was a two bolt flange mount, but had the same connections as the original. Opened it up when it came to see condition. Was pretty good, out came the Sawzall, off came the flange mount. I chucked the front housing in the lathe and cleaned it up and shortened the snout. Also the shaft, ended up doing this twice to get the correct set back from the belt. Also, the sheave was letting the belt ride on the bottom, so built a new one. (modified pump came without sheave) All in place and hooked up like original! One thing though, wait to put power steering on until you get the injector pump, lines, filters, and the like in place, or you will get to do it overrrrrrrrr!
  11. A little more update: The last power steering cylinder turned out to be in great shape, but the shaft was bent. I probably could have straitened it on the press, but it had radial cracks in it about every 1/2" the full length. The last thing I want is to have the steering head south while I'm in road gear! This is the old shaft and new shaft with both ends touching. This is the 'seal, wiper, guide' gland. The one for the last cylinder was perfect, so used as-is. This is the one from the old cylinder that I rebuilt to get more knowledge. First, I almost ruined it with my chisel. I had just rebuilt one for the late 560/660. They just had a straight split from the body to the cap, so a chisel tap was great. The 400/450 & early 560/660 (same cylinder number) the cap goes over the body. I did find that a quick shot of very lite penetrating oil cuts the surface tension and they almost fall apart. (I used WD40) Someone had beat on this one in other areas before I got into it. The "T" ring seal as they call it in the book came out with the backing rings in pieces. This seal is OBSOLETE per IH, so went on a look/see! On the out side of the cap is the shaft wiper. This model has a 1/4" thick hard felt wiper and a pressed steel retainer. I did not have any felt, and the cap was boogered up on this side also, so put in lathe for a little cleanup. By the way, the felt retainer came out fairly easy by using a flat blade screwdriver between it and the felt with a fulcrum outside of the retainer radious. (chisel) The cap ended up pretty chewed up inside the wiper area, so ended machining out to the late 560/660 specs. for a lip seal. In this last pic, the body is resting on the seal that I came up with. Its a X shaped o-ring. Called a qaudra seal!??(quatra?) Has four sealing edges, two inside, two outside My thinking is that there was some reason why Monroe did not use a plain o-ring to start with. It ended up having the correct compression with one backer ring (white) . This seal can be used on all 400/450/560/660 cylinders. The 600/650 use different part numbers, so???????
  12. After regaining my sanite! Did a little machining! Lil ackward but worked! Starting to fit up! Now for a big weld! And ya get this! Sorry for not being correct, but got fast hitch equip to pull!
  13. A little fill in from then to now! Have ya ever had no extra money! Had no gumption! All ya wanted to do is go to the shop and have a couple of cool ones! WELL it can get down rite dangerous!! Spair parts and frustrated hands can be a bad thing! Yup, It'l fit! Turbo is wrong size, off 99 Dodge 5.9 but it's doable! Time to lock up and get back to the house!!!!!
  14. Oh! To be a kid again!!!!!!!!!!!
  15. I did add more fuel, but as I was starting to take off the return line, I noticed that the throttle rod was not hooked to the pump arm. It was laying on it and each time I throttled up the rod slid down the pump arm until I had no throttle at all! ? Also tightened the bolts on the throttle pivot at the lower dash. Had a real good run today!
