Mish5288 Posted September 4 Posted September 4 My 5288 was mostly operating only on the low side, but would then have high side gears after running for an hour or so. Only use it for planting beans and chopping corn. Used it a few times this summer for odds and ends, now no sentry light and no movement. Grounds are good and I have power to each plug. Is it safe to run the test harness if I unplug one of solenoids so it only runs in high or low? I need to chop corn this week and was hoping that would get me by. I don't want to risk having both clutches engaged at one time and ruin the clutch packs. Hoping for advice. Quote
ComancheStarFarms Posted September 5 Posted September 5 (618) 795-3950. Mike Links owner of Triple R Tractors. Sharp technician, helpful & if you need his work then fair priced. 1 Quote
acem Posted September 5 Posted September 5 Unhooking a set if solenoids should work but I've never done it. Talk to Mike. He knows these tractors. Quote
HydroTek Posted September 5 Posted September 5 You can bypass the whole system and just use a SPDT toggle switch as the most basic setup Dont spend money on a "test harness" Spend on troubleshooting the sentry system or repair Once you understand how the sentry operates -- it really is a simple system 1 Quote
Drysleeves Posted September 5 Posted September 5 I've had no experience with the Triple R sentry module but everyone will attest it's the best option. Too good of a tractor to destroy with a cheap fix. Quote
Maynard Posted September 6 Posted September 6 On 9/5/2026 at 10:32 AM, Drysleeves said: I've had no experience with the Triple R sentry module but everyone will attest it's the best option. Too good of a tractor to destroy with a cheap fix. I have a 5288 in the shop now that has the new Sentry on it. The on board diagnostics is a real game changer. It's a blink system with a red and green LED that tells exactly what is happening. 3 1 Quote
hippy5488 Posted September 7 Posted September 7 On 9/4/2026 at 6:42 PM, Mish5288 said: My 5288 was mostly operating only on the low side, but would then have high side gears after running for an hour or so. Only use it for planting beans and chopping corn. Used it a few times this summer for odds and ends, now no sentry light and no movement. Grounds are good and I have power to each plug. Is it safe to run the test harness if I unplug one of solenoids so it only runs in high or low? I need to chop corn this week and was hoping that would get me by. I don't want to risk having both clutches engaged at one time and ruin the clutch packs. Hoping for advice. every time ive had no light and no movement. its always been the sentry reset/clutch safety switch or the wiring for it. Quote
cobfly Posted September 9 Posted September 9 On 9/7/2026 at 10:26 AM, hippy5488 said: every time ive had no light and no movement. its always been the sentry reset/clutch safety switch or the wiring for it. Yep Quote
buckeyefarmer89 Posted September 10 Posted September 10 I wouldn’t use the test harness. I would at least get a new sentry from Triple R Tractor. The last time I had a no light no shift scenario replacing the 2 relays in the sentry box fixed it. Make sure your batteries are up to snuff. Quote
