hippy5488
hippy5488's Achievements
the 310 has made it this long. a out of frame overhaul done correct will last another 40 yrs. there not the cheapest to overhaul but u can still get parts
its not the accumaltors. clutch pak
peacefull creek manuals, binder books or jensales although their not the quality of the first 2
the shear pin is the pin that holds front half of engagement dogs on the shaft. think maybe a 5/16 soft pin with cotter pin in it
for germ test wet paper towels place seed between them. put in a old cooler or anything that dont let much sun light in. put ten kernals in if 9 sprout u have 90% germ. if 8 sprout u have 80% germ
the pin that goes thru the drive dog is supposed to be a shear pin. its soft its supposed to break before gear or auger damage occurs. farmers being farmers the first pin that sheared got replaced with a grade 5 or 8 bolt that they had laying around
Is my Turbo seal gone or is it something else?
hippy5488 replied to MBman's topic in Technical IH Talk
some ivecos had a filter in the blowby recover system. they never get changed . then they put excess oil vapor into the intake air system. the filter is usually on the back of engine . looks like a square box. its supposed to be replaced every 500 hrs. to prevent this. i think im the only one in this area that replaces them every one that comes in the shop. nobody ever knows they have one and its suposed to be changed with every 500 hour oil and filter change -
Breaking loose wedgelock bolts that are really stuck.
hippy5488 replied to acem's topic in Technical IH Talk
1 in. impact, 200psi. shop air with 1/2 hose. havent had any that takes more than 10 min. to loosen -
does anybody know if someone is making new right hand console top pieces or where to get good ones from? dealer said nla. need the two top pieces tia
imho if your buying bulls that cheap they probably shouldnt be bulls. for 9 head i would be looking real hard at ai program. then try to keep some good hfrs. and keep with the ai. in a few years u could be selling a lot more pounds at the sale barn or maybe even sell a better bull than what u are going to buy for 1900
i wouldnt be afraid of the icons. i have been impressed with there quality. all my tools in shop are snapon or mac. service truck hasa little bit of everything in it from wright, williams or Slip and Kill. broke 2 SK ratchets 35 miles from home on a sunday. 10 miles from harbor freight store bought a long handle flex head 1/2 icon ratchet put 2 foot pipe on it. it took the bolts out that broke the anvils off the Slip and Kills
had the same experiance growing up. except when turning wrenches on stuffit was a older brother. u should see what he can do to steel hyd. lines or inj. lines when they dont thread on right away. my dad thought if working cows they should always be running. lots of screaming throwing dirt clouds and cracking whips
66 series steering tower/gear selector support isomounts.
hippy5488 replied to Sparky's topic in Technical IH Talk
look at mcmaster carr. have got the same design from them just dont know about the right size. however that seem more reasonable than 1990625c1 price. $69 a piece. the cable ends for magnum hyd. cables. blew my mind -
there is plastic bushings in the cross tubes for shifter and park. they wear out and let it drop down causing this problem
easiest way to tell if on no. 1 cyl. is to take the triangle shape cover off side of pump. theres a line on the pump head. if u can see the line u are on no. 1
