acem Posted December 25, 2025 Posted December 25, 2025 I thought the letter series only had one way hydraulics but I saw this old AD that showed an M with two hoses. So two way hydraulics were available on the letter series??? Quote
MacAR Posted December 25, 2025 Posted December 25, 2025 They could have a "Christmas Tree" valve installed, that gave you two way hydraulics. It was a dealer installed option, I'm not sure if any ever came from the factory that way. 1 Quote
Matt Kirsch Posted December 25, 2025 Posted December 25, 2025 I just happened to have a manual handy for the Stage I Super H, which would be the same belly pump setup as an H or an M. The proper technical term for the two-way hydraulics appears to be "remote control:" Quote
hillman Posted December 25, 2025 Posted December 25, 2025 10 hours ago, MacAR said: They could have a "Christmas Tree" valve installed, that gave you two way hydraulics. It was a dealer installed option, I'm not sure if any ever came from the factory that way. they are listed in my 1950 price book at $106.00 so they could be ordered with that option Quote
MacAR Posted December 25, 2025 Posted December 25, 2025 35 minutes ago, hillman said: they are listed in my 1950 price book at $106.00 so they could be ordered with that option I did not know that! Thanks! Quote
axial_al Posted December 25, 2025 Posted December 25, 2025 Back in the 1960’s, my dad put together a double acting hydraulic system on his 1948 M. He tapped into the pressure port on the right side of the belly pump and used a double acting Char lyn valve mounted on the light bar. The return line was plumbed into the reservoir fill port using a tee. He had a couple of pioneer remote ports on the rear of the tractor. I wasn’t aware that IH had offered that kit. Thanks for the post! Quote
drglinski Posted December 25, 2025 Posted December 25, 2025 Double acting hydraulics on a letter series are incredibly useful. 2 Quote
farmallcubkid Posted December 26, 2025 Posted December 26, 2025 On my m diesel there is a 2 spool valve for two way but instead of going through the fill port it has a 90 going into the drain plug. Quote
chadd Posted December 26, 2025 Posted December 26, 2025 Our 1940 Farmall M had the Christmas Tree valve added to the belly pump at some point in its life. The valve had a lever latch that would allow the valve handle to be locked so that the normal Lift-all lever could be used with single acting systems. It was locked that way for 30 years when the tractor was under a mounted New Idea corn picker. Quote
IH enthusiast Posted December 26, 2025 Posted December 26, 2025 I'm in the process of putting one of those on my 1940 M. Quote
acem Posted December 28, 2025 Author Posted December 28, 2025 Thanks for all the information. I didn't realize the letter series could have double acting hydraulics. They are a vast improvement over single acting. Thanks Y'all! 1 Quote
MT Matt Posted December 28, 2025 Posted December 28, 2025 On my H I just plumbed in an open center valve. Lock back the control rod of the pump and then you have two way hydraulics. It’s not the IH valve but works fine. Definitely don’t have the greatest lift capacity but it works good on a small brush hog. 2 Quote
barkerwc4362 Posted December 30, 2025 Posted December 30, 2025 Dad's Super M-TA had two way from the factory. 3 Quote
