Delta88 Posted July 12, 2025 Posted July 12, 2025 What do you guys use for a gasket sealant on a new water pump install? Quote
HydroTek Posted July 12, 2025 Posted July 12, 2025 Gray silicone -- do not use others as they can be corrosive with coolant I prefer the Kubota stuff, but permetex also has decent gray Quote
CIHTECH Posted July 12, 2025 Posted July 12, 2025 8 hours ago, Delta88 said: What do you guys use for a gasket sealant on a new water pump install? I'll be the odd guy here....why do people think they need an additional sealant on gaskets? If the OEM didn't use, and your gasket surfaces are clean & true there is absolutely no reason to use anything other than the gasket. Have spent hundreds of hours cleaning bolts, bolt holes an etc... because last guy used a sealant. I detest the stuff........ 10 Quote
Matt Kirsch Posted July 12, 2025 Posted July 12, 2025 1 hour ago, CIHTECH said: I'll be the odd guy here....why do people think they need an additional sealant on gaskets? 99 times out of 100, it's just easier than trying to grow a third arm. Little stick'um just to keep the gasket in place while I juggle the part, a bolt, and possibly a wrench with multiple extensions and universals. No need for gobs of the stuff, just a light smear. Quote
hippy5488 Posted July 12, 2025 Posted July 12, 2025 3 hours ago, CIHTECH said: I'll be the odd guy here....why do people think they need an additional sealant on gaskets? If the OEM didn't use, and your gasket surfaces are clean & true there is absolutely no reason to use anything other than the gasket. Have spent hundreds of hours cleaning bolts, bolt holes an etc... because last guy used a sealant. I detest the stuff........ best advice ive heard for awhile. dont understand why people need to use all the crap to get a gasket to seal. if u need to hold a gasket in place while installing a little spray hi tak works well. 4 Quote
IHandJDman Posted July 12, 2025 Posted July 12, 2025 4 hours ago, hippy5488 said: best advice ive heard for awhile. dont understand why people need to use all the crap to get a gasket to seal. if u need to hold a gasket in place while installing a little spray hi tak works well. I changed the water pump on my 1086 last year. CaseIH gasket came with some "stuff" on it that melted and sealed it. Quote
IHC_1470 Posted July 13, 2025 Posted July 13, 2025 For holding gaskets in place I just use a little chassis grease. 3 Quote
1967806 Posted July 15, 2025 Posted July 15, 2025 On 7/12/2025 at 7:57 AM, hippy5488 said: best advice ive heard for awhile. dont understand why people need to use all the crap to get a gasket to seal. if u need to hold a gasket in place while installing a little spray hi tak works well. And in the case of a water pump, spray the hi tack on the pump or the pump side of the gasket and not the block. Easier to clean up that way next time. 1 Quote
R190 Posted July 15, 2025 Posted July 15, 2025 On 7/12/2025 at 4:34 AM, CIHTECH said: I'll be the odd guy here....why do people think they need an additional sealant on gaskets? If the OEM didn't use, and your gasket surfaces are clean & true there is absolutely no reason to use anything other than the gasket. Have spent hundreds of hours cleaning bolts, bolt holes an etc... because last guy used a sealant. I detest the stuff........ I agree ,if there is no pitting you must deal with there is no valid reason to add extra crap to the sealing surface in most situations . I know a mechanic in a truck shop that goes thru a tube a day of silicone his work shows it. I think the money is better spent on a gasket scraper. Quote
