R Pope
Everything posted by R Pope
  1. I have a wide front M setup if anybody wants it. Front steer.
  2. Filling with water can do some awful damage! A neighbour tipped his WD9 into a slough at wide open throttle. One rod bent over at a 90 degree angle, and the crankshaft stopped so suddenly that the flywheel sheared all the bolts off and kept spinning. Broke the head and wrecked the block too.
  3. First. you have a distributor, not a magneto. Second, don't see a resistor in the coil circuit, or is there one that is not pictured?
  4. If you are looking for an original type engine, a W4 uses the same engine.
  5. Ask your Case IH dealer if the gas cap replacement deal is still in effect. I got a new 706-style cap for my W6 a few years ago, no charge. I think I had to turn in the old one, though, so maybe you're out of luck there. I hope the cap isn't like the rad cap! No longer serviced, the last price listed was about $180!
  6. Beauty! Great to see an IH with torsion front end instead of Mustang II or a Camaro clip and a 350.
  7. Never seen one with a bulge for the compressor! Cool!
  8. Sask466, good to see another stubble jumper doing cool stuff! Next time I go to Regina I will try to look you up!
  9. The Ford nuts call them "Slicks" now. Slick '60's, i guess. And they are slick!
  10. Pretty sure the bore is the only difference. It should bolt right in. Never actually done it though!
  11. W9 sleeves and pistons are hard to find! And rods and mains too. They are kind of an orphan, CIH doesn't sell anything for them. Just an aside, the magneto turns the opposite way to all other gas IH engines. Same way as the diesels, though. Don't let it put you off, though! The gassers are nicer to run, especially on quick little jobs, and they seem to have more power than the diesels. Never could understand why they never built a Super W9!
  12. Try to adapt car hubs to the M spindles and put some mags on the front. Even some spindle-mount dragster wheels might work!
  13. Get the shiny bits first! Gives you incentive to keep working on the dirty stuff.
  14. Had a loadstar with a 466. The doghouse was pretty big and the shifter was back between the seats, but it worked! All the bits for the cab should be out there somewhere. Maybe adapt the S series stuff----?
  15. a few truckloads of dirt will make a lot of difference.
  16. I have one too but I am Seville's neighbour.............
  17. That babbit might have been like that from day one! BTW, why does one have an oil groove and the other doesn't? Replaced at some time?
  18. I have a 22-36 rod bearing, it's an insert type machined from brass with a thin coat of babbit. Mid production change? The thing is a work of art! It weighs 2 1/2 pounds!
  19. Some pics might help.
  20. Most 806's had 8 bolt wheels. Later IH's had 6 bolt. The wheels tend to fold up easily.
  21. I have a good V800 in a 4586 with a blown differential if you want to go the stock engine route, lots easier than an inline swap.
  22. Yeah, it was in wrong way around. Never seen one fail that was in right. Trouble is, the groove can wear tapered with a wrong way ring, then it will never work right again.
  23. The snap ring may have been in backwards. The sharp edge must face outwards to hold against the internal pressure. You probably already knew that, but mistakes can happen........
