supermpuller
Everything posted by supermpuller
  1. Case never made a rotor combine
  2. I didn't say it was from IH,There were plenty of water filters from other sources
  3. I put water filter kit on my 1066 in 1974, it will solve the problem with cavitation,
  4. EV trucks and cars pay a fee yearly and some states have a EV surcharge tax.
  5. Under 3$ here
  6. I had a 2015 Freightlliner cummins IST 500 AT SmartShift Wilson 41 ft. hopper bottom trailer. Usually loaded to 85 thousand Ibs. Pulling out of field just put in low and walk right out, same when parked along highway shift into D and on your way. . once you pull a few loads the tranny will skip gears to for better MPG especially when running empty.It had a 10 speed
  7. Just like show cars, that semi can be set at any height you want
  8. I farmed with IH tractors , ran 450 460 808 560 966 1066 786 1086 3588 300U replaced 2 TA, I had 3 1066 and 2 1086, you can split gears and down shift in heavy tillage You'll have a tough time finding a IH in the corn belt without a TA
  9. My problem with JD is the ran 1920 technology till the 1960, as for hand clutch did you ever try to back a wagon into a barn with a JD G ?
  10. My dad and his 2 brothers ran turbos on 560's, 85 hp a couple of hear gaskets and broke a tooth of 4th gear in 5 years. Traded the 560's off for 806
  11. prayers sent
  12. if you follow NATPA rules you can pull any region from farm stock to div. 5
  13. hitch has to be 18 in back from center of axle or longer
  14. i use a 24 ft, VT, they were designed to chop the corn trash about 2 or 3 in deep you want to leave the corn root ball intack to keep the trash from washing in a heavy rain into a big pile in low spots or around open ditches. I run a 5 shant in line ripper in bean ground. Vertical tillage is up and down , a disk is horizontal or moving side ways and compacts the ground,
  15. 3588 had 466 motor
  16. CCR Fortunate Son and The Boss Glory Days
  17. Having fun at Woodstock
