Everything posted by Powered by IH
IH 674 block heater questions
Powered by IH replied to Willow's topic in Projects, Builds, & Restorations
Yes, I've seen a 574 diesel with a circulating coolant heater and it worked really well. -
Or this 1086...
Not mine: https://www.farmshow.com/a_article.php?aid=26365
Tricycle Front End Conversion From Wide Front
Powered by IH replied to ComancheStarFarms's topic in Technical IH Talk
Don't you have to swap dry to wet bolsters for that too? EDIT: Was thinking of a Hydro 100 instead of a 70. -
If you plug the top hose into the thermostat, I would worry about it opening and then trying to circulate the radiator coolant too. What usually works better is hooking lower hose up to the block drain, then putting a tee where the temp sender goes, then hooking the upper block heater hose to one side and the temp gauge to the other. That way you don't have to worry about the thermostat accidentally opening.
Did you pass? What were they looking for on the test?
A coolant heater might be easier and cheaper to install.
"Where do you guys get your Christmas hams?" "oh, we just pull them out of dad's garbage cans" 😆
On today’s episode of FB marketplace…..
Powered by IH replied to Oldironbestiron's topic in General Chat
They might be confusing it with the $40,000 H that sold recently. -
You could also try windshield washer fluid, might take a few 55 gallon drums though 😄
I have the I&T shop manual, so if you need any immediate pictures let me know. It might be a day or 2 though.
As long as you make sure to hit the power wash button a few times it isn't.
That would make a sweet setup with the single cab/long bed and zf6. Would love to have one someday! How many miles on it? Any rust?
Nice. Farm truck a 6.0?
Keep in mind though that the gas start diesels were designed for fuel economy, not pulling power. IH's campaign with those tractors was to do the same amount of work, but at half the cost.
Aww man, I'd love to do that job! Too far away though. Where are you located in central WI?
I would like a 450 diesel someday. But I don't know if I would actually use it to farm daily (as a heavy use tractor). Would like it mainly for hayrides, maybe some other work too.
Maybe a D312 instead?
Broughams are the "Platinum" edition of the cabovers. Premium interior and all the regular options, were standard on a Brougham I think. Speaking of Lazy WP's post, has anybody driven one of those cabovers with Jake brakes? If so what engine and trim package?
