Powered by IH
Everything posted by Powered by IH
  1. This guy did it... https://www.farmshow.com/a_article.php?aid=38952
  2. Here is an interesting animation of the ship sailing: Yes I know its not accurate because the ship sinks in one piece but is interesting to watch nonetheless.
  3. Does the donor tractor have a TA? Looks like it though. It is gas, look at the governor in last picture.
  4. What makes you want to replace the carburetor? Engine not running right? Welcome to Red Power Forums.
  5. Is the tractor in the background a Goldie or just a really faded red? Nice finds!
  6. I would investigate the cause of the failure in order to fix that too, just to be sure it doesn't happen again. Like what 560Dennis said with the oil pump.
  7. Detroit's are known for this: if one runs away, replace the shaft seals or the next time it runs away it might not shut down because of oil leakage from the last run away. (seen in cumminstinkerer's post) You said it yourself: when the inlet to the blower is plugged, the blower can't blow. Since the engine is still trying to pull air at high RPM's but the intake is blocked, a vacuum is created (like a choke in a gas engine), so the engine pulls oil and air through the weakened blower seals. I hope this explanation makes sense! ๐Ÿ™‚
  8. Youtube link is in this post. ๐Ÿ‘
  9. From Red 4WD Tractors:
  10. From what I understand: 4200's were made for 2 stroke v-type Detroits only; they were shorter BBC. The 4300's could have either inline 6's or V type motors; they had a longer BBC. I could be wrong though. ๐Ÿ™‚
  11. Are there any 2 stroke Detroits around or is it mostly Cummins? I know both were a very popular choice, especially in the older trucks.
  12. I love the 9370!
  13. Here is a great DIY video if you decide to do it yourself. It looks to be easy once the tranny is out! Getting it out is another problem though. Grr.
  14. Any pictures? I like pictures๐Ÿ˜
  15. Notice the sign even says they are FREE hay rides! The poor youngest brother was always the unlucky test subject...๐Ÿ˜† poor sucker
  16. Neat! Those grain bins sure make the binder look small...๐Ÿ˜€
  17. According to an IH serial number sheet and TractorData, your TD9B is a 1971 model. https://www.tractorparts.com/PDFs/IHSERIALNUMBERS.pdf https://www.tractordata.com/industrial-tractors/000/3/3/331-international-harvester-td-9b.html FYI: The support board is for website problems. If you have more questions, they would best be put into the "Technical IH Talk" or "IH Construction Equipment" boards where it would get more views. Have a good day!
