I found a very reasonably priced cast right step for our Hydro 70.  While attempting to mount it - - 2 heavy bolts - - I was successful in screwing in the forward bolt into the tranny or rear end housing however the aft bolt attaching hole has no threads.  Instead of threads for screwing a bolt into the cast housing it appears that it’s home to a recessed plug.  This should be similar to the 656, 666 & H86 and I’ve seen each with a right hand step.  Any ideas what I might be up against?
Posted (edited)
I just checked on my '65 F656 gear drive.  Casting number on the right side is 388118R1 (upside down on tractor).  The extended cast right under the brake pivot is threaded.  IH did send out their tractors with cork plugs in many of the threaded holes in the castings.  You can even buy those plugs for your restorations.  Should be a three quarters course thread hole.
Neal
Edited by naedlaen
spelling
Speaking of cork plugs, pretty much every IH 06-86  I ever worked on has a machined off place under the clutch housing with a dowel hole and 4 plugged holes with corks in them. Never ever seen anything mounted to them threaded holes or in the dowels. Any ideas what they are for?
One picture would let an old man sleep. My mind comes up with the pad where I model and I think hi clear front axle wishbones mounted. But when my mind starts drawing the mount. It only comes up with three bolts. I know I have to be crossing models or something.
7 minutes ago, snoshoe said:
Yup 4 bolts. Thank you
Seems like 3 bolts were mainly on wide front rear support ball pivot.
Photo "borrowed" from All States AG Parts which seems to be the only way to have pictures.
Now you can sleep. 😊
408814 | Stay Ball Socket | International | Farmall | IH Hydro 70 544 560 656 666 706 756 806 856 1026 1206 1256 1456 2544 2706 2826 2856 21026 21206 21256 |  | 535861R1
that one there would be the common one up front that bolts to the removable cross piece axle support thing, the one they were thinking of above, is where a Hi Clear would mount,  to the  rear of the bell housing right?
That makes sense now about that MFD bracket. I suspect the dowel hole could have just been a locating point for machining fixtures. I sure would like to have been able to stand there and watch all the machining process happen on the TA housing and rear end housings when they were being built.
On the Deere side, my son in laws grandfather retired from deere in waterloo several years ago. He was a production machinist. I had a pretty good talk with him about that stuff one day. He told me one of the stations he worked at was machining the lifter bores in the 5020 engines. Another one of the places he worked in was where they machined the transfer case/housing/whatever you want to call it on the 7520 articulated 4WD's. He said it was about an 8 hour process to get one all machined properly back in the day. Just thinking just for the housing, then all the hours to cast/forge/cut/machine all the internal parts. Tons of hours in that stuff.
Made a few trips over to the Louisville plant to see the different machines at work over the years
Pretty cool stuff to learn about
I think last time was for the '50 series drive train
was a new machining setup
only 4 guys running it
Raw housing on one side of a "U" shape and finished on the other side
lots of surface cutting , drilling, and tapping in the big "U"
Stamping crankshafts on that huge press in the other building
the whole floor shook as the press dies came together
4 big bolts holding the press together -- about 60 feet vertical -- they said just as much in the ground
Big flywheel and camshaft at the top that moved the die up and down
58 minutes ago, snoshoe said:
Machining setup sounds like what I saw at Rock Island. Last saw it at Racine machining housings for magnums.
Only went to Rock Island a couple of times
Been to Racine several times also -- some cool machining centers there
You ever get to goto Burr Ridge ?
 I had to go to Racine several times for tractors I'd never seen before. 94 series. and 4wd. Best thing about it was in the summer the Union Grove raceway was just 10 miles down the road.  They were open every night.
https://www.greatlakesdragaway.com/
On 9/2/2026 at 6:59 PM, snoshoe said:
Pull the plug out and behold a threaded hole.
You are correct.  Any idea why one casting threaded hole out of dozens on the tractor has a plug & none of the others have anything - - other than mud dabbers?  Thanks for the help!
All the others fell out/were removed over the last 55 years?
