I have nine, 10, and 11sright now on 06/66’s and unfortunately I think it depends more on the tire manufacturer then on the size . I posted recently that I bought a set of 9’s that measure two within an eighth of an inch of a new set of tens, and they are over an inch wider than my older set of Nina’s.  I have a 10 year old set of firestone 11s that are huge, Neighbor has a much newer set of offbrand ones that I want to say are probably 2 inches shorter. My 11s are on tractors with 20.8s
100 percent spot on here.
There are so much variation between manufacturers that it's hard to say for sure.
Unfortunately there is too much variation within manufacturers too.
I was looking at Firestone/Regency
They fit on my 1456, but it's close for sure.
i had an 1486 in our shop here set up that way one tire rubbed one didn't I do not remember the brand tires vary quite a bit.
Exactly. A month or two ago i installed two new tires (same tires, same rims) and one was running 1/4-3/8” closer to the stop than the other. I broke that tire down and remounted it the other side out.  “Should” not have changed anything, but when I did….it actually got Closer. Then I got mad and took them both back off.
IMHO it's a crap shoot. There's enough manufacturing variations in the spindles and just a fraction of a degree can mean the difference between rubbing and racing...
10" rims with the proper offset is about the only guaranteed way.
