hardtail
Everything posted by hardtail
  1. How much is it over?
  2. Missed this post, did you put it back together, with running video im guessing yes? What did you end up doing with the pump coupling up front? Engine sounds really good and clear exhaust, you might have some cold weather coming your way in a couple days
  3. Once the temp dropped it was somewhat common to run diesel equipment 24/7 My uncle was using his TD18 in cold weather years ago and it wouldn't start so he built a fire under the belly pan and went for lunch, oil and crap ignited and he had a small fire when he returned, can still see the extent on the underside of the sheet metal
  4. Any broken linkage or fork issue would have the clutch pack fully engaged, I would look at final drive problems on that side
  5. That might be the best chappy can be, best to look for Rokon if you need more😁
  6. Online sales has taken a lot out of brick and mortar, the Prime van wave is daily
  7. My cousins neighbor had a diesel Chevette that flat towed a dead Dodge diesel hooked to a trailer one day, a little embarrassing...
  8. It might be a larger town but the population is still in decline, I think the council likely has no idea how to run things properly much less stimulate over 100% growth
  9. If you have a MD doesn't the tractor already have one, or you want a spare?
  10. Worked at a local college from 87 to 89 and biathlon was one of the colleges sports, think it was fairly new back then, good Ole days when students were carrying rifles on campus with no ill intent, the community has a large Scandinavian culture
  11. Well buddies 873 that is incredibly reliable quit out in the field yesterday so she's spending an evening outside, see how the shop queen likes that, luckily very warm here currently We used to use those kind of heating pads in blanket warmers in the hospital, the cabinets were stainless so we would have to glue them on with silicone
  12. Can't be much snow left around Millet today and ground under windrows will be frost free, he can use whatever he wants, depends on the size of trees left, our timber doesn't get very big up here usually
  13. He has a TD15, not sure if he ever got a root rake? I would use the dozer
  14. My buddy has a 873 with Duetz, he uses almost daily and it's parked in his heated shop but it's cold here for half a year
  15. Broken taps can be nasty, I usually have good luck with broken off items with patience and a diamond point chisel, if you have drilled it out you can usually start to separate a piece from the hole and eventually collapse it, this has worked well on piping, it can be successful on bolts but you need a full bag of tricks sometimes Great description Snoshoe and congrats Marty
  16. Changed a bit, Star wars styling
  17. Rydlyme we used to throw antacid tablets into the juice if there is no fizzing the solution is spent, I might be tempted to flush it both directions to get big flakes out of top and bottom tanks? Those rads weren't really a highly pressurized system dont overdo it on your test
  18. KOO swore by carb cleaner Buddy poured used motor oil down the stack on a 1091, took a year but free
  19. I took fluid mechanics in 82 in tech school, years later had to take some again for power engineering, as I reimmersed myself after years I thought man this sure seems like complicated formulas, went and grabbed my old fluid mechanics textbook and viola super simple 3 value formula for same problem, that's when I took the easy exit ramp, not sure what they were trying to accomplish there...
  20. I had a FMX in a 65 Galaxie, they are a beefy transmission with separate valve bodies and tubing for each speed IIRC Still can't remember what I did with it and especially the Ford 9"🤔
  21. Hate to say but finding stuff will likely get worse if your like me, I would relish getting hit in the head with what im looking for some days
  22. See drops of blood, reckon he finally surrendered and send me back to the penal colony down under
  23. I don't think the new ones will serve you as well as what you have now
