Posted
This is how the tractor was when i purchased it a year ago for $1200.00.the 10ftto bushhog didn't come with it ): 2013-08-04_17-47-14_682_zps5c84dca6.jpg
Posted
2013-08-04_17-50-15_781_zps655cc0f4.jpg New range cover and all new parts inside.also had to replace reverse shift fork.it was broken and tractor wouldnt shift into reverse. Rebuilt all shifting linkage at this time also
Posted
2013-08-04_17-51-59_945_zps223b420c.jpg I belive my tractor originally had a narrow frt end.someone switched it to the wheatland frnt end.i hope to get a row crop frnt end some day
Posted
Things i havent taken pics of include, all new glow plugs,rewired whole tractor,replaced all leaking seals, new steering wheel etc etc.the list goes on and on!
Posted
looking very good, nice job on the mechanicals . do it right the first time and the tractor is a lot mor fun to work with
  • 2 months later...
Posted
nice lookin 10 johndeerefan, you should be very proud of it. one of my all time favorite tractors
and welcome to the forum :D even with a name like that, lol
Posted
x2!! :)
  • 3 weeks later...
Posted
The M project.
I tried to start it but discovered that the starter was bad too!
The neighbor is coming today to try to pull start it so I can at least see if the engine runs now and I can drive it up into the barn.
All thats left if to put the decals on and the tin and the mud guard above the front wheels.
Now if I can just hear it run once! :unsure:
Posted
Hopefully this reprocess of my original pic will go thru...
We did get it running!
Video to follow later.
Man does she go!
Power to burn!
Posted
GRRRRRR!
Cmon! the message only stays on the screen for a second.
How low res does it have to be???
  • 1 month later...
  • 3 weeks later...
Posted
Here is a 1942 A Farmall that I bought in July, 1992, in Elbert County, GA. After I purchased it, I found that it was in an estate that was being disputed. I finally brought it home two weeks ago - 19 months, later! I got it running, and it runs GREAT - even though it needs to have the carb rebuilt. A potential "show-stopper" is that when I poured coolant in it, coolant ran out from the torque tube, in front of the clutch. It would be a shame to give up on it, because it has great oil pressure. I will have to split it to find out where the leak is.
Posted
attachicon.gifA.bmp Here is a 1942 A Farmall that I bought in July, 1992, in Elbert County, GA. After I purchased it, I found that it was in an estate that was being disputed. I finally brought it home two weeks ago - 19 months, later! I got it running, and it runs GREAT - even though it needs to have the carb rebuilt. A potential "show-stopper" is that when I poured coolant in it, coolant ran out from the torque tube, in front of the clutch. It would be a shame to give up on it, because it has great oil pressure. I will have to split it to find out where the leak is.
Most likely the frost plug has rusted out at the back of the block.
The original part number would have been 23139V , water jacket expansion plug, 2"
Marty
  • 4 weeks later...
Posted
1947 MD, new sleeves and pistons 50 hrs. ago, Injection pump gone through last yr. New base coat/ clear coat
This topic is now closed to further replies.
