pt756 Posted April 19 Posted April 19 Finally ran out of the old spray 2150 cans, Tried a new one, doessnt seem to have that wide spray pattern like old stuff, However will try another can, also is there another brand of spray can that works just as well, Quote
Matt Kirsch Posted April 19 Posted April 19 "Works as well" or "matches the color and holds up the same?" For the latter, no. For the former, if you don't care about color matching, I've always had good luck with Rustoleum products. Quote
rustred Posted April 20 Posted April 20 20 hours ago, pt756 said: Finally ran out of the old spray 2150 cans, Tried a new one, doessnt seem to have that wide spray pattern like old stuff, However will try another can, also is there another brand of spray can that works just as well, i have noticed that also on some spray cans. with a wide spray pattern you can do a good job. some cans just have a straight spray pattern and its a buggar to paint . Quote
1967806 Posted April 20 Posted April 20 Had a similar problem with a spray can of copper seal the other day. Old one sprayed fine before I got it empty and new one was to small of a stream. Thought I'd just switch nozzles. Couldn't do that either. Old can had the stem on the nozzle that fit down in the can. New can had the nozzle sticking out of the can that fit up in the nozzle. 😠 Same brand and everything. Quote
stronger800 Posted April 20 Posted April 20 Gotta save all assorted random nozzles for things like that. Put a big orifice Brake clean nozzle on a can of paint, if your not going for perfection, (think moldboard plows for storage) and things happen Fast 2 Quote
