Posted
Years ago, l worked on a dam project in eastern Oklahoma. They had a IH scraper like the one in the pic along with a comparable sized Allis-Chalmers and two Cat DW-21's. Wen l first went to work there, l ran a old Cat D8 pulling a sheepsfoot roller. lt was so old and wore out that in order to turn to the left, you had to make a full circle to right. Then l got "promoted" to one of the DW-21's. Didn't have any brakes so in order to slow down or stop, you had to CAREFULLY lower the pan. Those were the days....lol
Posted
Back in the day a old Army truck and few I beams and old set of tandems are you where moving houses
The accident happened in Moundridge, KS, when the rear wheels of the trailer broke through the planking of the bridge spanning Emma Creek. Circa 1954.
  • Like 5
Posted
A International D-246-F truck owned by the Ontario Department of Highways clears snow from the streets of a rural area.
Posted
International D-246-F Power Divider with two driveshafts one to each axle.
This was before the interaxle differential was integrated into the front axel on the tandems
Drive Shaft to back axle
Posted
This interesting a drag line on a Steam Traction engine
I certainly don't have the Professors knowledge to identify the engine
Posted
Instead of a drag line, is that what they called a fresno?
Posted
I guess its kind of in between
drawn out with with a team and pulled back with the traction engine
Posted
l was just curious. l've only seen those pulled with mule teams. While l'm here, l'll post this. l know Gary always liked the Roadrunner-Coyote jokes so thought l'd post this one. lt's captioned "How it all started."
  • Haha 3
Posted
It's hard to tell, but it almost looks as if there's a solid bar connecting the engine to the scoop... I wonder, was it meant to be pushed into material then lifted up and used to load wagons? We'll never know I'm sure, but it's fun to speculate!
Posted
Yes all speculation, but the guy that thought it out was thinking much better than a shovel and wheel barrow.
My speculation is, used like a fresno. The cable lift on the back adjusts the cutting and dumping eliminating one man.
Posted
You may be right, Ray. I'm not familiar with a fresno, but I have used one of these a time or two:
The Buck Scraper and the Oxen — Law Family Homestead
They were called slips here, and pulled by one or two horses. I guess a fresno is just a bigger version? What I do know is they were hard on the horses pulling them and even harder on the man holding the handles... I can tell you that when that cutting edge catches a rock, those little handles will flip you azz-over-teakettle!
