sshannon74074 Posted March 4, 2025 Posted March 4, 2025 Ive been combing the internet for the replacement seals for the remote. Its the outer 2 that I need. should be a hard plastic oring and a slightly larger black rubber o ring. Does anyone have a link or info where to find these? Thanks! Quote
HydroTek Posted March 4, 2025 Posted March 4, 2025 Try the tractor dealer 511524 oring 544792R1 seal Change those couplers out to the Pioneer kit Quote
Sparky Posted March 5, 2025 Posted March 5, 2025 Yes, your local CaseIH parts counter has these in stock. I understand why people switch those IH couplers to the ISO kit, but I don't understand why they like them. I prefer the IH coupler. Travis Quote
Bermuda_Ken Posted March 5, 2025 Posted March 5, 2025 Most of the new 2025 year and later CIH tractors have lever operated hyd couplers now......funny how old is new again.....😄 1 Quote
HydroTek Posted March 5, 2025 Posted March 5, 2025 2 hours ago, Sparky said: Yes, your local CaseIH parts counter has these in stock. I understand why people switch those IH couplers to the ISO kit, but I don't understand why they like them. I prefer the IH coupler. Travis The IH lever style coupler was better in my opinion -- but most did not know how to work them and had troubles -- like bending the levers and difficulty connecting Not sure how many of them I have repaired over the years Put the tractor valve in float and you could connect when the hoses had pressure was a nice feature 1 Quote
HydroTek Posted March 5, 2025 Posted March 5, 2025 31 minutes ago, acem said: Try just replacing the O Rings first. Yes -- likely the leak is from the oring inside of the female part of the coupler , where the male tip seals Easily replaced when looking in the coupler -- I don't remember the number ISO kit 1272964C94 Quote
brahamfireman Posted March 5, 2025 Posted March 5, 2025 4 hours ago, Sparky said: I understand why people switch those IH couplers to the ISO kit, but I don't understand why they like them. I prefer the IH coupler. Travis Because adapters suck. 98% of tractors in the world use the small couplers. if you own anything outside of a 66 or 86 series IH, you'll need to have adapters around because all your equipment will have small ISO couplers. Quote
Sparky Posted March 5, 2025 Posted March 5, 2025 25 minutes ago, brahamfireman said: Because adapters suck. 98% of tractors in the world use the small couplers. if you own anything outside of a 66 or 86 series IH, you'll need to have adapters around because all your equipment will have small ISO couplers. All of my equipment has the large IH ends....and my couplers don't just randomly fall out. Travis Quote
Jeff-C-IL Posted March 5, 2025 Posted March 5, 2025 I always thought the IH tips were better as well. Back when I had mostly IH tractors of that era, I had the IH tips on the main lift hoses, and Pioneer on the wing hoses. Made it easy to get them hooked up right! Unfortunately....the "aftermarket" tip became the standard everybody used. And now that I have a 9230, JD7410, & NH 9030 - all with Pioneer couplers - ain't got much choice. Quote
acem Posted March 6, 2025 Posted March 6, 2025 I agree the 66/86/88 coupler system is better but I also have other, smaller tractors that use pioneer style. So I try to have one pioneer and the rest IH style on my 66/86/88 tractors. Works pretty good for me. I dislike the adapters. Quote
brahamfireman Posted March 6, 2025 Posted March 6, 2025 4 hours ago, Sparky said: All of my equipment has the large IH ends....and my couplers don't just randomly fall out. Travis I wasn't lucky enough to only buy IH 66 or 86 series tractors. So its very impractical to put large IH couplers on equipment, and then box myself into a corner and only be able to use 1 tractor on my equipment. 15 tractors here with hydraulics, 1 with large IH couplers, only 1 tractor has issues with spitting out a hose, and it's only on the #1 remote. Quote
