Everything posted by ComancheStarFarms
Where is a good Mid West source for buying a tricycle front end for a Farmall 656 - closer to Indiana the better.
Sounds as if you’ve got all the info you need for a decent fix - - but it’s hard to not find an upholstery shop in an Amish community. I’ve had two curtains made that turned out better than new and cheaper than if I made them myself - - one in Windsor, MO and another in Odon, IN. Iowa has plenty of communities to check out.
If you want good or better condition original manuals then try the “The Paper Farmer” at (715) 726-1942. Peaceful Creek makes a high quality reprint.
Try Bob.Obert@Titan-Intl.com
Stolen Tractor Serial Numbers
ComancheStarFarms replied to ComancheStarFarms's topic in Technical IH Talk
Thank you stronger800. We’re ok. But I think it occasionally happens & RPF looks to be the perfect platform to help when it does. -
Who’s keeping a record of stolen tractors?
I’ve purchased a couple dozen PAR 36 4.5” LED lights from Larsen & have had very good use out of them - no failures.
Dry in the south also. Never want to turn down rain but sure makes good working weather. No Wheat since the 80s. Your area grows a fair amount - right?
How’s it going for you?
Just finished the last of our hay yesterday. Beans about 2 weeks away. Corn maybe 2+ weeks - dry weather past two weeks helps a lot. Slight pause will give us a chance to cut about 10,000 board feet of timber. Bedford for us.
Just caught me by surprise & no big deal. I’m in IN also & not yet 40 in our area. Maybe the 40s but not 40. But it’s coming soon enough.
This is my experience with my family’s two Hs & a Super M - - all three purchased new by my grandfather & father & in my custody for past 30+ years. Sediment bowl works great - - clever engineering contraption - - until it doesn’t. At that point it can be hours over days to figure out what went wrong with such a simple system. All the various issues already listed above. Eventually everything comes together & then trouble free again for years. If that’s your experience then stick with it. But I stopped farting with it years ago & went with aviation fuel line & an inline filter along with a shut off valve. Oh, and I threaded it to the tank with a 1” extension into the tank to prevent sucking gunk. Driving up on a neighbor whose glass bowl cracked & poured gasoline on the starter which evidently sparked when cranking over the engine & then reduced his MTA to ashes was my deciding point. I did similarly with the two 6V batteries - - they worked great until they don’t & then a whole list of things to identify “what went wrong.” A single Group 31 now does the starting for us.
Cracked Wedge Lock Cast Center
Mudfly - you might be onto something for the cause. nate - that’s been my plan up to now. Just haven’t found any yet. brahamfireman - I don’t mind the driving - once drove a 715 combine from Mullen, NE to Beaver, OK & that took all of seven hours (& a little more). Just hard to believe that in a (once?) big farm state like IN that wedge cast centers for a 38” wheel aren’t closer at hand. Thanks all! -
Buying a newer cast center is a definite “yes.” I’ve been aggressively hunting for one since I found the 1st crack. Not as easy to find within 200 nm of home as I thought. I’ve never seen one cracked before either, that’s partly why I’m trying to figure out the cause. No desire to have a repeat or catastrophe. Thanks! -
I agree with you. Bought the tractor from the estate of an older farmer & his family said he just did a little bush hogging. Being a hydro I didn’t think the rear end would ever be seriously stressed. But a lot happens in 50 years. i don’t know if the 1st spoke was cracked when I purchased it - didn’t notice it. I found the second spoke just a couple weeks ago & all the tractor has done is drive on level ground with no load on it or behind it. Just adjusting the hydro unit. Thanks bitty! - Jonathan -
About 6 months ago I posted an issue on our 1026 that it had a crack across ine of the spokes on the right rear cast center. 10 working hours later - easy work - and a second spoke has cracked. What’s going wrong?
Need 38” Wedge Lock Center
ComancheStarFarms replied to ComancheStarFarms's topic in Projects, Builds, & Restorations
Good info. Thanks -
Not with wedge lock centers. -
Wedge Lock Cast Center for 38” Wheel
Great! Thanks! -
I do appreciate the help - AR & MO & WI & IA will be backup plan. Still going to be driving across OH. -
My mistake - 3.25” wedge lock cast center is what I need - - it’s for a Hydro 186. I forgot that was one of the differences from a 1086. I’ll check with both Knights & Colfax but since I’ll be driving from Youngstown, Ohio to west of Cincinnati I was hoping to save on shipping. So any leads in Ohio on a 3.25” wedge lock cast center? Thank you for the already good help! -
Anyone have a source for the potential purchase of a good condition wedge lock cast center for a 38” rear wheel on a 1086 - in Ohio? I’m also posting this in “Technical.” Thanks in advance.
Anyone have a source for the potential purchase of a good condition wedge lock cast center for a 38” rear wheel on a 1086 - in Ohio? I’m also posting this in “Restorations.” Thanks in advance.
