Good evening, was going to replace the pins that hold the 3 point arms on, done it before, first time these pins are stuck in there, what are some of the tricks to get them out I did cut one side with thin blade, now arm is off now there is about 1/4 inch of the pin left in the tractor casting, did heat before milking now it will turn a little bit, still have to do the other side, would you weld a big nut and then try to heat the casting up? thanks, it is cat 3
Yeah, sounds like those pins
Rarely do the pins wear out -- usually the bushings in the arm
Weld a bolt onto the stub long enough to use the outer part of the arm as a "puller"
-- the welding and cooling will shrink the pin stub
-- then use anti seize on the thing when you go back
Have drilled the pin thru and put in a grease fitting to push the pin stub out a couple of times
-- that is a blind hole in the casting -- so grease will force the pin out
Well took all the advice, so today I took a 3/8ths flat bar about 15 inches long. drilled a 1 inch hole in it, fit it over the pin, welded it, left drove around for a while, came back and started tapping the bar, little by ltiile it started to come loose, put a pipe on it and got more leverage and out it came, was going to do a 1 inch nut but for me to reach in and weld it, thought the flat bar would work, thanks
Funny thing is I occasionally have trouble with the bolt backing out and the pin falling out. Not getting stuck.
Same with wide front end tubes.
