I recently restored my 856.I love her just the way she is ,but it weighed 12,876 pounds.Ive been doing some pulling and at that weight I'm hitting some much bigger cubic inch competition.I removed the fluid Wich I should have done anyway.I also installed a narrow front.I still use the tractor on the farm.I know I sacrifice some control ,but how much stability.Any input would be appreciated!
It's my own opinion that a narrow front affects ride quality more than stability. Most of your stability comes from the rear wheels.
As you know wide front ends pivot in the center so that they can oscillate over uneven ground (why they ride better). The tractor has to tip quite a ways before the wide front comes up against a stop and does anything to stabilize the tractor. Usually by the time that happens it's too late; the tractor's already going over.
I've been using it on my v-max spreader and I'm not noticing any problems.Its a little strange not seeing the tires out front is all . I do think I'm going to have to invest in a full set of front wieghts ,but the turning has been better than I expected.
Wide fronts are more stable because the roll center is higher, up under the front frame, while the narrow front pivots at ground level. Trikes usually turn much sharper, though.
  • 2 weeks later...
Have an 806 narrow front and wide front. Like said the wide is a bit more stable but definitely not much.  It’s deceiving because by the time the thing leans hard enough to hit the stop you’re already dead. Just be sensible. Take it easy, especially turning from headland into field going downhill. if you think it might roll don’t go there or go at an angle.
Just play it safe. I’ve seen daylight under the uphill tire of an h before raking hay and it’s not a good feeling
In these situations the more weight the better for stability
I put one under my 1456...............Use it to grind feed for the most part.  I was going to widen out the rear but decided to leave them in narrow.  With your rears widened out you should be fine.  I got 10 bolt duals to put on this if we really have to use it, it would take alot to tip it then for sure.
  • 2 weeks later...
I absolutely love this narrow front! It turns on a dime.I also have duals for it.Im looking forward to hooking up and doing some plowing.spring is near my friends.im ready for the smell of freshly plowed dirt.
  • 2 weeks later...
If you do that please take some pictures for us. I like an arrow front also. Depends on the job somewhat but all in all I like that look on a larger framed tractor. Does it have a turbo like the sticker suggests?
Yes I installed a m+w turbo last year.It gives it a little more snap.It pulled 128 horse on the Dyno.Since then I've been working on the pump a little also,but I haven't had it back on the Dyno.
Here’s my 806 gas with narrow front and factory cab.  Only 3000 hours
We have an 806 with a narrow front, bought new, but it's not very original anymore. Love it anyhow.
It pulled an 800 8 row all over then retired from planting when we went to 30" rows.IMG_0011.thumb.jpg.f21e31e7f60093f767f8309748826d6f.jpg
Now it mostly just plows snow, and wears a Year a Round cab.
The more recent photo is from this summer when we had the cab off to do some work on it and I painted the sheet metal at that time and had to snap a few pictures.
I love big frame narrow fronts!IMG_20170720_151828148.thumb.jpg.9153929e94b91b38bb3443809d9a569f.jpg
17 hours ago, Jbailie said:
Got this pic today right before I went to moldboard plow sod
:wub:  Get any plowing pictures?
