vtfireman85 Posted September 9 Posted September 9 2 hours ago, Binderoid said: We have to use Never-Seez on everything in Ohio, and that seemed to keep the connection clean and tig I have had arguments about this with people before, if you lubricate the threads you can apply proper torque, which keeps things tight, the argument being always that something will loosen up if you lube it. My dealer got all upset that I used never seize on my lug nuts, I personally have never had a properly torqued lug nut loosen up. Quote
supermechanic Posted September 9 Posted September 9 5 hours ago, Binderoid said: We have to use Never-Seez on everything in Ohio, and that seemed to keep the connection clean and tight. 3 or 4 cans in my kit, down to where the brush won't reach, but way too much in the bottom to throw out. 2 Quote
farmallcubkid Posted September 9 Author Posted September 9 7 hours ago, Binderoid said: The universal failure point around the solenoids on those and the later Power Strokes is the output stud , whether it be from corrosion or looseness (or corrosion FROM the looseness), making high resistance heat and the eventual destruction of the connection and solenoid housing. We have to use Never-Seez on everything in Ohio, and that seemed to keep the connection clean and tight. I experimented mounting them on rubber blocks cut from a tire, after I observed the solenoid on my '95 PowerStroke vibrating to the point of being blurry...I thought, "Well, that can't be good for it". Solved the problem on the PowerStroke but it not definitive if it helped the PC 7.3. I just never had any more trouble with them if I was lucky enough to get it apart after it was cooked. When I got the donor motor, I went to hook the glow plugs up and broke the output terminal. It just broke right off but you could try to break the other ones and it wouldn't. It was strange the way it broke off too. 8 hours ago, Diesel Doctor said: I just watched an episode of "Watch Wes Work" and he replaced a glow plug solenoid on his. He said those control the ground and not the power, so you are stuck with that type of solenoid. Those are a tough engine. Show it a little love and it will treat you right. I figured that out and thought that it was kind of strange that the switch controlled the ground instead of the power side on the solenoid. Was it easier to produce or cheaper to make? Those motors are sure tough too. Quote
Binderoid Posted September 9 Posted September 9 2 hours ago, supermechanic said: 3 or 4 cans in my kit, down to where the brush won't reach, but way too much in the bottom to throw out. If you have plastic cans, cut the bottom of the can off about 1-1/2" high. Great for dipping bolts in. Or get an old toothbrush to scrape off the bottom. People whine about how messy it is, but if you take reasonable care of your tools, it isn't a problem. Quote
Binderoid Posted September 9 Posted September 9 6 hours ago, vtfireman85 said: I have had arguments about this with people before, if you lubricate the threads you can apply proper torque, which keeps things tight, the argument being always that something will loosen up if you lube it. My dealer got all upset that I used never seize on my lug nuts, I personally have never had a properly torqued lug nut loosen up. A friend refused to use my table saw after I Never Seezed the blade nut. He was certain the blade was going to come flying out, but he didn't understand the concept of left hand threads. 4 Quote
vtfireman85 Posted September 10 Posted September 10 2 hours ago, Binderoid said: A friend refused to use my table saw after I Never Seezed the blade nut. He was certain the blade was going to come flying out, but he didn't understand the concept of left hand threads. He wouldn’t like a 3 tooth molding head then would he? https://www.ebay.com/itm/327335250223?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=327335250223&targetid=2295557531950&device=m&mktype=pla&googleloc=1027378&poi=&campaignid=21404249913&mkgroupid=173029508828&rlsatarget=aud-1412318123216:pla-2295557531950&abcId=9450098&merchantid=427105305&gad_source=1&gad_campaignid=21404249913&gbraid=0AAAAAD_QDh__NCJEsGrSzppnuvkg9UIfc&gclid=Cj0KCQjwh4TVBhCWARIsAG0czmpkb4Osjtt4kX9BsUgu10KUBlvH1Eo09I1glky9YXFW6nnI9Tks2x4aAigCEALw_wcB Quote
supermechanic Posted Thursday at 07:26 AM Posted Thursday at 07:26 AM 5 hours ago, vtfireman85 said: He wouldn’t like a 3 tooth molding head then would he? https://www.ebay.com/itm/327335250223?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=327335250223&targetid=2295557531950&device=m&mktype=pla&googleloc=1027378&poi=&campaignid=21404249913&mkgroupid=173029508828&rlsatarget=aud-1412318123216:pla-2295557531950&abcId=9450098&merchantid=427105305&gad_source=1&gad_campaignid=21404249913&gbraid=0AAAAAD_QDh__NCJEsGrSzppnuvkg9UIfc&gclid=Cj0KCQjwh4TVBhCWARIsAG0czmpkb4Osjtt4kX9BsUgu10KUBlvH1Eo09I1glky9YXFW6nnI9Tks2x4aAigCEALw_wcB Those things are loud. I spent two weeks making cove with the exact set in a radial. Quote
vtfireman85 Posted Thursday at 01:51 PM Posted Thursday at 01:51 PM 6 hours ago, supermechanic said: Those things are loud. I spent two weeks making cove with the exact set in a radial. They work well, but I won’t lie, they make me uneasy. Quote
brahamfireman Posted Thursday at 08:25 PM Posted Thursday at 08:25 PM 23 hours ago, supermechanic said: 3 or 4 cans in my kit, down to where the brush won't reach, but way too much in the bottom to throw out. If we could post pictures, I inherited a 5 gallon pail of anti seize when I bought the farm. Metal pail , still half full. Quote
searcyfarms Posted Friday at 01:50 AM Posted Friday at 01:50 AM my neighbor has two 7.3 idi - underpowered if you ask me - but i suppose reliable not sure Quote
