MacAR Posted May 1, 2025 Author Posted May 1, 2025 12 minutes ago, snoshoe said: You've asked this before and I answered in the negative. The purpose of the ball was to keep high pressure oil out of the low pressure side. Iirc the only time ball would unseat was if the engine ran backwards. Like when you shut it off. That being said. I do not know who makes this pump or how it is made. It may be a copy but is not one of the pumps I worked on. You're exactly right, should have went back and looked! Quote
MacAR Posted May 1, 2025 Author Posted May 1, 2025 20 minutes ago, roy1066 said: 15 years or so ago I bought a 450 diesel and it kept blowing the seal out. After some head scratching I figured out it had a gas pump on it. Got a diesel pump and put on it and solved our problem. Part number of old pump and new pump each cross to a gas pump. Good thought though! Quote
jeeper61 Posted May 5, 2025 Posted May 5, 2025 On 4/30/2025 at 9:21 PM, MacAR said: Part number of old pump and new pump each cross to a gas pump. Good thought though! Any luck finding the issue? Quote
MacAR Posted May 5, 2025 Author Posted May 5, 2025 46 minutes ago, jeeper61 said: Any luck finding the issue? Well, maybe. Take a look at this: That middle valve wasn't fully in single acting mode. I cleaned a lot of grease out of it, and now it seems to seat: Ran out of time to mess with it much more today other than putting another key in the pump and putting it back together. If I have time tomorrow I'll stab it back on and see what happens. I'm gonna bring it up off idle a bit more too, to see if I can work the new pump in a bit better. 1 Quote
HydroTek Posted May 5, 2025 Posted May 5, 2025 Those valves are closed center should be no oil flowing thru them , unless the valve handle is pulled The unloader does the trick of routing the oil for the open center pump Quote
MacAR Posted May 5, 2025 Author Posted May 5, 2025 5 hours ago, HydroTek said: Those valves are closed center should be no oil flowing thru them , unless the valve handle is pulled The unloader does the trick of routing the oil for the open center pump Hmm.... that's interesting. Someone had said earlier that the valve being stuck between single and double can cause problems similar to what I'm having. Is that true? I have no idea. Quote
snoshoe Posted May 5, 2025 Posted May 5, 2025 19 minutes ago, MacAR said: Hmm.... that's interesting. Someone had said earlier that the valve being stuck between single and double can cause problems similar to what I'm having. Is that true? I have no idea. Yes it's true. The load sensing ports won't line up causing the unloading valve not to open. 1 Quote
MacAR Posted May 5, 2025 Author Posted May 5, 2025 6 minutes ago, snoshoe said: Yes it's true. The load sensing ports won't line up causing the unloading valve not to open. So just looking at my picture, do you think it was out of it's notch far enough to cause an issue Sno? I'd hate to button it all back up and still have a problem! Quote
HydroTek Posted May 5, 2025 Posted May 5, 2025 33 minutes ago, MacAR said: So just looking at my picture, do you think it was out of it's notch far enough to cause an issue Sno? I'd hate to button it all back up and still have a problem! Look close at the roll pin -- sometimes they can get bent and make the valve out of register Quote
MacAR Posted May 5, 2025 Author Posted May 5, 2025 3 minutes ago, HydroTek said: Look close at the roll pin -- sometimes they can get bent and make the valve out of register It's hard to see, but that roll pin looked pretty darn straight.... I'll check it again tonight when I get home. Quote
snoshoe Posted May 5, 2025 Posted May 5, 2025 1 hour ago, MacAR said: So just looking at my picture, do you think it was out of it's notch far enough to cause an issue Sno? I'd hate to button it all back up and still have a problem! Yes entirely possible. As Hydro mentioned a bent pin can do it. Still have a problem with it being "the" problem. If that will shear the key. It will shear every time a cylinder hits the end of stroke or steering to stops. Quote
MacAR Posted May 6, 2025 Author Posted May 6, 2025 2 hours ago, snoshoe said: Yes entirely possible. As Hydro mentioned a bent pin can do it. Still have a problem with it being "the" problem. If that will shear the key. It will shear every time a cylinder hits the end of stroke or steering to stops. You're probably right. I made sure the pin was straight so probably not the whole problem. I didn't have much time to mess with it today unfortunately. One thing I did do is make darn sure the nut on the pump was good and tight; this last time it took very little effort remove it. Made sure the gear was driven down tight too. Doubt that has any bearing on it but don't hurt to be sure. First chance I get I'll dig into the regulator and see what I can find there. After that, I'm at a loss. Quote
snoshoe Posted May 6, 2025 Posted May 6, 2025 Seems foolish to me to tear into it without some indication it's on pressure or the pressure is to high. On pressure should be easy to tell by listening. Engine will run more freely when a cylinder is moving or you are steering. What the pressure is requires a gauge. Did I miss something? Was thinking key shearing started with new pump. Still my main suspect. Quote
MacAR Posted May 6, 2025 Author Posted May 6, 2025 18 minutes ago, snoshoe said: Seems foolish to me to tear into it without some indication it's on pressure or the pressure is to high. On pressure should be easy to tell by listening. Engine will run more freely when a cylinder is moving or you are steering. What the pressure is requires a gauge. Did I miss something? Was thinking key shearing started with new pump. Still my main suspect. You're right, it started with the new pump. The old pump wouldn't hold a seal on the distributor side more than 5 minutes. Anytime the steering was operated or a valve moved it started pouring oil. The new pump spins just as freely as the old one if that makes a difference. This last time when it went, I didn't do anything other than fill the reservoir and start the engine. Never touched a valve (all in neutral) or moved the steering wheel. I'm half tempted to put the old pump back in after I check the regulator out. I really wish that I could find a gauge setup that I could plug in the regulator, that'd tell us really quick what the problem is. Could a guy just buy a 2000 psi gauge and make up a hose to plug into a remote? Quote
snoshoe Posted May 6, 2025 Posted May 6, 2025 A gauge can be pipe bushed into a male tip to plug in to a remote. Quote
MacAR Posted May 9, 2025 Author Posted May 9, 2025 Ok @snoshoe and others, I think I found my problem: Those 3 washers were under the safety valve spring... since they're not in the parts book I can only guess someone was trying to overcome a weak pump or a bad spring. Fortunately, I had another safety valve spring here that measures a hair longer, so I put it in sans washers. Just need a bit of gasket material to make a new gasket for the top cover before I button it up and try it. I'm not 100 percent sure this is the problem but I can't imagine it's good for the pump; I can also state that if I could get my hands on the SOB that put those in there, I'd give him a bloody good education! Quote
snoshoe Posted May 9, 2025 Posted May 9, 2025 1 hour ago, MacAR said: Ok @snoshoe and others, I think I found my problem: Those 3 washers were under the safety valve spring... since they're not in the parts book I can only guess someone was trying to overcome a weak pump or a bad spring. Fortunately, I had another safety valve spring here that measures a hair longer, so I put it in sans washers. Just need a bit of gasket material to make a new gasket for the top cover before I button it up and try it. I'm not 100 percent sure this is the problem but I can't imagine it's good for the pump; I can also state that if I could get my hands on the SOB that put those in there, I'd give him a bloody good education! I used 5/8 lock washers. 1 lockwasher would raise about 200 lbs. Remember steering is 1900 psi. That is only 1200 to start. Rockshaft lift on a 234 picker requires something over 1300 to raise. Seems rockshaft lift was cheaper to buy than cylinder lift. 1 Quote
MacAR Posted May 10, 2025 Author Posted May 10, 2025 It's aaaallllliiivvvee!!!!! I punched a gasket out of an oil filter box quickly, and put all back together. Fast hitch raises and lowers, power steering goes lock to lock, and no labor on the engine. Think I can safely say she's back in the game! Now need to replace a bad valve cover gasket and put the hood sides back on and she can go to the field! Thanks guys for your ideas and help! 3 Quote
R190 Posted May 12, 2025 Posted May 12, 2025 That was a 1960s method of increasing the operating pressure one washer is all we ever used, it would increase the pressure a couple hundred pounds. Quote
MacAR Posted May 12, 2025 Author Posted May 12, 2025 6 minutes ago, R190 said: That was a 1960s method of increasing the operating pressure one washer is all we ever used, it would increase the pressure a couple hundred pounds. I can see just the one thinner washer. But two thin ones and one that's half again the size of the others is a bit excessive to me! Quote
HydroTek Posted May 13, 2025 Posted May 13, 2025 19 hours ago, MacAR said: But two thin ones and one that's half again the size of the others is a bit excessive to me! Really depends on what the pressure gauge reads Some of my customers would pull a planter and needed more pressure to lift fertilizer box that system can do 2000 psi if the pump is in good shape Quote
MacAR Posted May 13, 2025 Author Posted May 13, 2025 1 hour ago, HydroTek said: Really depends on what the pressure gauge reads Some of my customers would pull a planter and needed more pressure to lift fertilizer box that system can do 2000 psi if the pump is in good shape True; but with a brand new pump I'd say it probably wouldn't need much if any shimming... right? All I'm going to be lifting is a haybine, bush hog, or disk cylinder. Not going to have a loader on it, and not going to be doing a lot of heavy lifting on the fast hitch. I'll run it the way it is a little while, and if it's not up to snuff I'll drop a washer back in there. Quote
HydroTek Posted May 13, 2025 Posted May 13, 2025 1 hour ago, MacAR said: but with a brand new pump I'd say it probably wouldn't need much if any shimming. The pump has nothing todo with the pressure unless the pump is not able to output enough to start with These are low speed pumps in the first place , only running at half of engine speed the more modern systems run the pumps much faster , so internal leakage is less of a problem this statement is not for the piston or vane pumps in current tractors Quote
MacAR Posted May 13, 2025 Author Posted May 13, 2025 Ah so, copy copy. I admit, I'm not very good when it comes to hydraulics. The rest of the machine I understand pretty well, but the hydraulic system has always mystified me. So the $64,000 question is: should it be shimmed or not? Guess I need to test it first with my equipment and then adjust accordingly? Quote
HydroTek Posted May 14, 2025 Posted May 14, 2025 Needs to be shimmed according to the pressure you need I think original was 1200 psi that was not enough to lift a planter -- but really depends on what you need lifted 1 Quote
