MacAR Posted April 27, 2025 Posted April 27, 2025 I bought a new pump for the 450, since it wouldn't keep a seal in it. When I went to put it back together the other day, it ran for just a bit and sheared the woodruff key. Chalked that up to a buggered up drive gear keyway, so had a new keyway machined in the gear last week. Put it back together this afternoon, and again it ran for a bit and sheared the key. I cannot figure out what I'm doing wrong. I put the gear on and tightened the nut as tight as I can get it. This time is even sheared the fold over lock washer off. I bought this tractor last month and have got to use it less than 2 hours total. I'm about ready to torch the thing and start over! Can anyone offer any advice or ideas as to what's causing this before I break out the matches and gasoline? Mac Quote
Matt Kirsch Posted April 27, 2025 Posted April 27, 2025 Did it ever work with the old pump? The old pump may have been pushing out seals because the hydraulic system is dead-headed and that was the weak point. The new pump is tight enough that it goes for the next weakest point which is the key. It should not make any "whining" or "hydraulic" noises normally. Try just looping the suction directly to the pressure on the pump with a hose full of oil, or maybe circulating into a bucket of oil. That will tell you if the problem lies in the pump or in the rest of the system. Dad's Super M would shear the key any time he raised the endgate on the spreader all the way. Deadhead the system, boom, sheared key, instant ground driven spreader. It did have a relief valve, but that didn't seem to make any difference. 1 Quote
MacAR Posted April 27, 2025 Author Posted April 27, 2025 19 minutes ago, Matt Kirsch said: Did it ever work with the old pump? The old pump may have been pushing out seals because the hydraulic system is dead-headed and that was the weak point. The new pump is tight enough that it goes for the next weakest point which is the key. It should not make any "whining" or "hydraulic" noises normally. Try just looping the suction directly to the pressure on the pump with a hose full of oil, or maybe circulating into a bucket of oil. That will tell you if the problem lies in the pump or in the rest of the system. Dad's Super M would shear the key any time he raised the endgate on the spreader all the way. Deadhead the system, boom, sheared key, instant ground driven spreader. It did have a relief valve, but that didn't seem to make any difference. Seemed to work just fine the bit that I used it. The old pump was quiet and still seemed pretty stout, it just wouldn't hold the seal. When I started it the first time, the sump was low but I could see oil moving in it. There wasn't enough oil to work the lift or power steering, so I shut it off, filled the sump, and before I could test either one it sheared the key again. I'm thinking of disconnecting the power steering and looping it together first, because for some reason I feel like it's part of the problem. It worked well but seemed to whine a bit; I just chalked that up to normal old tractor things but now I'm second guessing myself. I'm also wondering if there isn't a big air pocket somewhere. Don't know if that could cause it or not. Also haven't checked the filter now that I think of it; could that be it? Quote
Matt Kirsch Posted April 28, 2025 Posted April 28, 2025 I don't think an air pocket would cause the system to deadhead. Air is compressible. The power steering is supposed to be running off of a priority valve, with the vast majority of the flow going through the valve bank and back to the sump. Unless someone routed full flow from the pump to the power steering motor, but then I'd expect the motor to explode within seconds of startup. The priority valve could be malfunctioning, I guess. I also don't think the screen is strong enough to cause a deadhead. When it's too badly plugged, it generally just splits open. 1 1 Quote
HydroTek Posted April 28, 2025 Posted April 28, 2025 I would think that the relief valve would keep from shearing the drive key -- unless the relief is hanging up the relief is located in the regulator block under the 4 bolt plate on top of the valve -- with the big spring unloader is the piston and valve next to the relief The original system power steering got oil from the regulator block on the end of the remote valve stack Yours connected there ? Quote
MacAR Posted April 28, 2025 Author Posted April 28, 2025 51 minutes ago, HydroTek said: I would think that the relief valve would keep from shearing the drive key -- unless the relief is hanging up the relief is located in the regulator block under the 4 bolt plate on top of the valve -- with the big spring unloader is the piston and valve next to the relief The original system power steering got oil from the regulator block on the end of the remote valve stack Yours connected there ? I was wondering if the relief valve isn't hanging up. Doesn't look hard to check, unless I'm missing something. My only hang up is I'm not sure what I'm looking for when I check it. The PS is plumbed into the regulator block; the only problem I had with it was one hose was weeping but I tightened it up and the weep stopped. I had another thought: Could the pump bypass ball be hung up? I hate to think that's the case on a new pump, but as it's sitting on the bench now would be the time to check it. Of course, that might not be it either since the old pump kept blowing the seal out, and if something was deadheading that would be the more likely culprit. Quote
snoshoe Posted April 28, 2025 Posted April 28, 2025 Check ball in pump malfunction should only blow out seals. Steering relief is the high pressure at 1900 psi and it pressurizes entire pump output when engaged. You need to check pressure some how. If pump will run long enough to check if engine loads or runs freely when steering or actuating a cylinder. Quote
MacAR Posted April 28, 2025 Author Posted April 28, 2025 6 minutes ago, snoshoe said: Check ball in pump malfunction should only blow out seals. Steering relief is the high pressure at 1900 psi and it pressurizes entire pump output when engaged. You need to check pressure some how. If pump will run long enough to check if engine loads or runs freely when steering or actuating a cylinder. Seems like it was under a bit of a load when I tried to move the steering wheel, but only for a moment or two since moving the wheel caused the key to shear this last time. The time before it was actuating the fast hitch. It went up and kicked out like it was supposed to. When I started moving it down, it sheared the key. When I reinstalled it yesterday, with an almost empty reservoir, the engine didn't load up, I could see oil moving while it was running, but I had no hydraulics or steering. It was only after filling the reservoir that it popped the key. Quote
snoshoe Posted April 28, 2025 Posted April 28, 2025 52 minutes ago, MacAR said: Seems like it was under a bit of a load when I tried to move the steering wheel, but only for a moment or two since moving the wheel caused the key to shear this last time. The time before it was actuating the fast hitch. It went up and kicked out like it was supposed to. When I started moving it down, it sheared the key. When I reinstalled it yesterday, with an almost empty reservoir, the engine didn't load up, I could see oil moving while it was running, but I had no hydraulics or steering. It was only after filling the reservoir that it popped the key. Is this a higher displacement pump? Should get a gauge in there and see what pressure is. Quote
MacAR Posted April 28, 2025 Author Posted April 28, 2025 2 minutes ago, snoshoe said: Is this a higher displacement pump? Should get a gauge in there and see what pressure is. Its not supposed to be... here's the link to the one I bought: https://www.ebay.com/itm/294293440762 Here's a theory, you tell me what you think: the reason the old pump kept blowing seals out within 5 minutes of putting them in was due to something going on elsewhere in the system (priority valve seems likely, could be elsewhere too). Now that new (tight) pump is in, the key is the weakest link and so it shears. Unless the key is/was a very soft one not meant to be used in this application. Hadn't thought of that either. Just spitballing here. I'm going to go see if I can find pressure test gauge on my lunch break here in a bit... probably won't but can't hurt to look. Once I have it though, I don't know what I'm looking for.... thoughts? Quote
snoshoe Posted April 28, 2025 Posted April 28, 2025 3 hours ago, MacAR said: thoughts I always have plenty. Usually pretty jumbled. With gauge in remote outlet,engine running just fast enough to keep from dying with hydraulics loaded. Actuate remote. Should read 1200 psi. With gauge teed between regulator and steering. Steer to stops. Gauge should read 1900 psi. If those two checkout. It becomes a pump and key problem in my mind. 1 Quote
MacAR Posted April 28, 2025 Author Posted April 28, 2025 Thanks sno. Got a lot going on this week but I'll try and get to it and report back. Still looking for a gauge setup... I would have thought someone in town would've had one but so far I've been skunked. Quote
jeeper61 Posted April 28, 2025 Posted April 28, 2025 I was thinking about the key hardness too. They only problem with hard keys is they do more damage when they shear 1 Quote
MacAR Posted April 28, 2025 Author Posted April 28, 2025 That has crossed my mind too.... but I don't think it's the cause of the problem. I do have the old key from the old pump, I think I'll try it and see if it works when I put it all back together. 1 Quote
HydroTek Posted April 29, 2025 Posted April 29, 2025 Run a file across each key -- this will give some idea of the hardness 2 1 Quote
MacAR Posted April 30, 2025 Author Posted April 30, 2025 On 4/28/2025 at 9:20 AM, HydroTek said: unless the relief is hanging up the relief is located in the regulator block under the 4 bolt plate on top of the valve -- with the big spring unloader is the piston and valve next to the relief Just curious, what do I need to look for when I open the regulator up? I know there's supposed to be a tiny screen in there somewhere, and a check ball, but if you (or anyone) could give me a step-by-step I'd sure appreciate it! Quote
snoshoe Posted April 30, 2025 Posted April 30, 2025 2 hours ago, MacAR said: Just curious, what do I need to look for when I open the regulator up? I know there's supposed to be a tiny screen in there somewhere, and a check ball, but if you (or anyone) could give me a step-by-step I'd sure appreciate it! Really don't think your problem is in there but can walk you through the valve. Under the top four bolt cover is main relief, unloading valve and orifice. The relief spring is stiff. Remove one cover bolt. Find two bolts a 1/2" longer. Install the longer bolts in diagonal corners. Evenly remove other two bolts then the longer ones. Keeps things from flying. Reverse process to reinstall. In one bore will be relief spring and spring seat cup. Under that is the actual relief valve plunger. In other bore is unloading valve piston. Make sure plunger on bottom of that is not bent or beat over. Is still spring loaded and free. Want a new oring on this as well. Under the piston is ball seat, ball and spring. If seat is tight, ball is seated and when depressed returns to seat. I do not go further. If you need to. It requires a drag link socket with a notch in the center to clear the ball. Between the two bores is a screwdriver slotted plug with a hole in the center. This is the unloader orifice. Screen attached to underside. On side of block is a plug held in by snapring. Behind that is flow divider spool followed by spring. In end of spool is steering orifice. With flow divider out and steering line and fitting removed from bottom. A screwdriver can be inserted from bottom to remove slotted ball seat, ball and spring of steering relief valve. Recent 450 power steering thread with lots of pictures. Can't seem to get his handle right. 1 Quote
MacAR Posted April 30, 2025 Author Posted April 30, 2025 Thanks @snoshoe, that seems fairly straightforward if a bit complicated but I'll give it a whirl. Something else I was looking at tonight after I pulled the gear: the part of the key that engaged the gear is only about 1/16 to 1/8 of an inch above the shaft... it seems like it should stick up higher for lack of a better description. It was a fairly hard key though, I tested it with a file. I'm still trying to find someone that has a test gauge I can borrow, but so far they're either not willing to loan it out or just don't have one. Does anyone have a recommendation for one I can just buy? Looks like rhats my only option now. Quote
MacAR Posted April 30, 2025 Author Posted April 30, 2025 I'll check that out, I remember reading it but at the time I didn't pay much attention to the details. Quote
snoshoe Posted May 1, 2025 Posted May 1, 2025 I really don't know what is causing your problem. I don't ever recall the problem on this model. I know others have said different. I am also reminded that I have been out of service for 20 years. At this point I am very suspicious of your new pump. These are pressure loaded pumps. Meaning that they use hydraulic pressure to push the side plates against the gears. It doesn't take to much imagination to visualize those pucks acting as disc brakes if material or dimensions have changed. Thinking on these lines makes me wonder what oil you are using. A trans-hydraulic oil like Hytran should have very extreme lubricating properties that a straight hydraulic oil may not. Just more thoughts to keep you awake. Quote
MacAR Posted May 1, 2025 Author Posted May 1, 2025 4 minutes ago, snoshoe said: I really don't know what is causing your problem. I don't ever recall the problem on this model. I know others have said different. I am also reminded that I have been out of service for 20 years. At this point I am very suspicious of your new pump. These are pressure loaded pumps. Meaning that they use hydraulic pressure to push the side plates against the gears. It doesn't take to much imagination to visualize those pucks acting as disc brakes if material or dimensions have changed. Thinking on these lines makes me wonder what oil you are using. A trans-hydraulic oil like Hytran should have very extreme lubricating properties that a straight hydraulic oil may not. Just more thoughts to keep you awake. Very true... the oil I'm using is a generic hy-tran/hy-gaurd compatible oil. I've used it for years in my 300 and so far no issues with it. Could it be possible the pump check ball is stuck or screwed down too tight? As you said, just something else to keep you awake! Might be worth checking on the off chance the spring is too long and not letting the ball off the seat. Quote
roy1066 Posted May 1, 2025 Posted May 1, 2025 15 years or so ago I bought a 450 diesel and it kept blowing the seal out. After some head scratching I figured out it had a gas pump on it. Got a diesel pump and put on it and solved our problem. Quote
snoshoe Posted May 1, 2025 Posted May 1, 2025 20 minutes ago, MacAR said: Very true... the oil I'm using is a generic hy-tran/hy-gaurd compatible oil. I've used it for years in my 300 and so far no issues with it. Could it be possible the pump check ball is stuck or screwed down too tight? As you said, just something else to keep you awake! Might be worth checking on the off chance the spring is too long and not letting the ball off the seat. You've asked this before and I answered in the negative. The purpose of the ball was to keep high pressure oil out of the low pressure side. Iirc the only time ball would unseat was if the engine ran backwards. Like when you shut it off. That being said. I do not know who makes this pump or how it is made. It may be a copy but is not one of the pumps I worked on. Quote
