Little Red
Little Red last won the day on February 25 2025
Little Red had the most liked content!
    South Dakota
2,920 profile views
Little Red's Achievements
1.3k
  1. I figured he was raised using hieroglyphics and has been slowly learning English, I can understand about 20% of what he’s trying to get across now, a few years ago it was closer to 0
  2. 4430 has a 46 gallon tank, 1466 has a 42 gallon tank. That makes it even worse 😂, I knew they were similar in size but had to look it up to tell you exactly how much.
  3. My old friend Roger has a worn out 1466 that he ran a mixer wagon with, he would fill it with fuel on Saturday and run it all week to feed his cattle and refill it with fuel the next Saturday. His son in law talked him into buying a pretty nice 4430, I think the only thing that didn’t work was the fuel gauge, he decided he would use the 4430 to feed cattle with, with the same exact mixer wagon feeding the same exact ration to same exact cattle and made it to Wednesday or Thursday before running out of fuel after filling it up the previous Saturday. He was fairly disappointed with the deeres drinking problem!
  4. The 706 diesel I have is probably my favorite to run, it is the smallest one of the bunch and could use some more power but I understand its limitations and use it accordingly.
  5. According to my nutritionist, not enough to get much benefit from the garlic mineral
  6. That’s why I mark the outlet ports on the tractor too, upper ports on 66/86 series and lower ports on 7110 and then the ports are side by side on the blue magnum I have, which doesn’t get hooked to anything that the smaller tractors get hooked to.
  7. I zip tie my hoses together for each function so they can’t be mixed up, I also put a zip tie on the lift hose of the two hoses and have a zip tie or wire marking the lift port on remotes of the tractor.
  8. I’ve heard some say it works great and then someone else says it doesn’t work because cattle don’t sweat 🤷‍♂️
  9. It’s quite ironic, someone that became rich from singing songs about choosing the wrong guy for dating then tells us who to vote for
  10. Just kidding, I heard it on the news yesterday, whoopdy-doo, could not care less!
  11. Here’s some pictures of the under side of shift plate, had to do this to my 966 exactly a year ago. Ordered a kit from hy-capacity, has all the parts you need. The pictures are from right after I took shift plate off I should have taken another picture after everything was replaced.
  12. Neighbors 100+year old hip roof barn. Building at my place, used to be a wall with some doorways in the end where the horse trailer is parked. The remnants of a pole shed at my place, some of the tin is laying 3/4 of a mile away in my pasture. Cottonwood limbs in my backyard, didn’t take pictures of the front yard.
  13. Pretty sure it was not a tornado, the destruction was several miles wide and many many miles long, not sure where it started and where it ended but im 70 miles ne of sdman and there is pretty significant damage around my neck of the prairie. Heard someone say 112mph winds somewhere by me.
  14. Hope sdman and everyone around there is fine. Been hearing a lot of reports of buildings destroyed. I will post pics later
