39farmalla Posted yesterday at 01:00 AM Posted yesterday at 01:00 AM Question to all the CC guys What fluid do you use in the hydro? How much? A quart? A gallon? Also does anyone have the filter part number ? Where is the serial number? TIA, Sam Quote
Alan Dinan Posted yesterday at 03:43 AM Posted yesterday at 03:43 AM Find a Viscosity oil dealer and get Ultraction. It’s the original HyTran. Don’t know how much it holds or the filter number. Quote
Alan Dinan Posted yesterday at 03:46 AM Posted yesterday at 03:46 AM A quick google search says 923-3014 for the filter 1 Quote
snoshoe Posted yesterday at 05:10 AM Posted yesterday at 05:10 AM Capacity should be just under 2 gallon. Serial number is just to the left of the rear cover on rear housing. Thinking should be a riveted plate by then. Earlier ones are stamped into the cast. 1 Quote
Mr. Plow Posted yesterday at 01:47 PM Posted yesterday at 01:47 PM 7 qts, hytran, high quality hytran substitute, type F transmission fluid, JD HyGard.....all acceptable and approved by Sunstrand (OEM). Fleet Guard HF 6096 (from memory).......DO NOT use a car oil filter, even if it fits, it needs a hyd. suction filter to operate correctly. 1 Quote
drglinski Posted 10 hours ago Posted 10 hours ago Fill it till it's just below the level of the fill plug on the rear cover. Viscosity ultraction if you can't find IH hytran. Quote
