Posted
Howdy,
Looking to get a new rear rim or two for my H and found some that say they have a 4" center rib do you know if this will fit my centers or does this need to be 3" only to fit?
thanks
Posted
Depends on where they measure. Deep drop rims have a rounded or slanted drop most times that gets a little wider at rim than at wheel. If 4 inch at wheel the clamp bolts may not be long enough. Original rims measure around 3 to 3-1/4 at rounded part to wheel depending on measuring at what side of round.
Posted
Thanks for the information on this DWV.    Could be a fit with longer bolts or will there be an issue with the locks getting into the squared off portion do you think?
thank you
Posted
I buy Titen rims they have the center drop with welded on toque lugs 38 inch. choose your Weith, fits H or M same thing, look pretty much stock painted a nice clean silver. See your tire dealer and order a set.
