farmalldr
Everything posted by farmalldr
  1. Looking at pictures and info on the BTD20, it has appearance of TD20 (201 series), gear drive too. Different engine though. Maybe @Binderdan has parts coverage for TD20, 201. Could it be the same? I don't have info for either one. Pictures may help but they are not working right now. Dennis
  2. Double check the part number. Looks like too many numbers to me. Most #s that start with a 3 are 6 digits plus the R #. Not familiar with BTD machines however. Good luck. Dennis
  3. What you have going on may be completely normal but checking it out may be justified. The drain back hose is on the lower right side of the bell housing and returns to the front of the transmission or the main case. The fitting in the bell housing has the trough built onto it. You'll have to remove the fitting to see the trough. If the machine ever had a starter bendix failure the trash from that can collect in that fitting and restrict the flow. Also, on top of the converter is a vent, early models, or it may be piped back to the rear case, later models. Make sure it is venting. Early 175's, which yours might be if it has the Drott loader frame, had a washable safety filter in the converter out circuit. This is mounted inside the frame next to the engine on the left side. This is where you would find aluminum trash if a converter failure occurs. If your machine is running normal and converter temps are staying normal, I don't think any of this is pertinent. Make sure the starter is sealed. Dennis
  4. The Bell housing on a 175 and others is wet do to normal leakage. The flywheel when running picks up the oil, throws it into a small trough at a return hose which takes it back to the rear case. It is possible it is over filling because of a converter problem but you generally will have trans/converter heating problems. The starter needs to be a sealed starter. S/n on a 175 should be on the left side of the seat.
  5. Good to hear Bill. Many do not have anything to go back to. Unbelievable pictures on the news. Take care. Dennis
  6. @Brady Boy, stay safe Bill. We are all thinking about you and your neighbors. What is happening in your area is unbelievable. Dennis from Othello
  7. I agree with @Binderdan. I think more than one vendor supplied a given part. Dennis I have no verification for this.
  8. Might try here. F P Smith in Calif. https://www.fpsmithparts.com/parts?gad_source=1&gad_campaignid=23960156760&gclid=CjwKCAjwsfzSBhB5EiwAOGyqSSx3qzsVQwzdaixFMA1rJ8pf1UbWYL2ZJQnNzzSeuszzWAx6rzMBMxoCi6oQAvD_BwE
  9. Here is a picture from the service manual. Hope this helps. Dennis
  10. @farmallcubkid, Yes you will have to remove the pan. The pan bolts to the flat plate that is under the lower seal retainer. Be sure to check your pot metal seal retainers for flatness where they bolt up to the block. They are known to warp. They can be sanded flat on a piece of glass or something you know is flat. Have fun and good luck. Dennis
  11. Well snoshoe, you have a little shade along the wall at least. lol. I am 82 also and now have the choice to work or rest under ac conditions. I choose the ac. Take it easy out there. Dennis
  12. Not Mike, but yes it is a 92 series. Saw it today. Done up nice too. Dennis
  13. Planning to be there for the entire show. Going to start wandering that direction tomorrow. Traveling with a fifth wheel rv. Dennis
  14. The model and serial number is stamped on a flat machined surface on the side of the block. Can't remember which side for sure. Try the right side first. Dennis
  15. To add to the other comments the 239 engine has a balancer mounted below the crankshaft and is gear driven off the crank. The balancer has to be timer to the crank. Check the balancer closely. Dennis
  16. Sleeve o rings would dump coolant to the oil but not oil to coolant.
  17. I believe the DT239 had an engine oil cooler, not sure if the D239 did. If yours has the cooler, have it checked. The cooler could cause oil to get to the cooling system. Dennis
  18. Does look like that but actually is 338BHP, brake horse power. Dennis
  19. These specs may help with your trouble shooting if you do not already have them. Make sure the rest of the drive train is working properly also. Good luck. Dennis
  20. @JonCraigHere is some info on your #s. They are the left and right link of the chain. Left and right side of the machine are the same. Your assys are for TD7C and E should fit TD6. Drop the V in part numbers for berco #. This is some fairly old info. Good chance none is available new anymore. If they are new or good, someone needs them. Number of links is important also. Dennis
  21. Sorry to hear this. Condolences to the Miesners. Dennis
  22. Are you sure you have a 1975 model? What is your s/n? Machines after s/n 9500 had what is considered the small transmission and a common oil supply for the rear case, transmission and converter with one dipstick. Machines before 9500 had a rear sump separate from the transmission as Binderdan discribed. Dennis
  23. I don't think the TD18's had hydraulic assist like the later machines such as TD20 or later. The assist was a spring for each lever. You'll have to take a look to be sure. It's been a long time. Sure would be nice if the clutches and brakes are free. I think you have a chance if it has been undercover. Good luck. Dennis
  24. My phone started working again on its own a couple days ago. I didn't change or do anything. Go figure
  25. My android doesn't get on the technical or construction but the computer does. Been that way for a while. So, I am no help. Dennis
