Snox38
Everything posted by Snox38
  1. After your reply’s we dug through my Cat kit and found some that seem to work. It is going back together and will hopefully be done tomorrow.
  2. I should have spent more time chasing down lines. I appreciate the info on it. Thanks
  3. Thank you for the responses. I greatly appreciate it. Thought it may be but it was extremely flat
  4. My dad has a 1086 and we have a split o-ring. We are having trouble figuring out the part # is and what it is called. I have included pictures to hopefully help. It is a block for return lines. It is under the starter and connects to the transmission case behind the bell housing. We looked through Messicks but still have no clue. Appreciate the help
  5. Went for a ride today. A little new snow and found a nice lace with no tracks. We are about 3’-4’ short in this spot.
  6. We had to go on a service call yesterday to a customers house. Wish there was more snow but at least got a short ride. First one of the season.
  7. Welding holds as long as you keep your knives sharp. We have found it’s better to replace. If it’s limited use I would think welding would work and keep them sharp
  8. I have a Montazuma. It’s been used and abused and held up well . I think it is the medium size and gets heavy to move back and forth when completely loaded
  9. That is exactly what I’m referring to. I’ll see if we can get a harden washer with a longer bolt. The bolt seems to stay but beat the washer off. Thanks for the reply
  10. My dad’s 560 has lost the hydraulics. We have narrowed it down to the driven gear on the driven shaft from the PTO. What it looks like is the gear is sliding down the shaft away from the gear for the hydraulic pump. We are wondering what the parts should look like. We put a new bolt and washer on the end of the shaft and the gear shortly beat the washer off and moved away from the pump. Not sure what is wore out or if there is a sleeve that is missing. Any help is appreciated. I will ask him with any questions that come up.
  11. My buckshot mudders worked good with my 03 Cummins. They didn’t last the longest though. I had them sipped and it made a huge difference
  12. My second set of Danner Quarry’s done exactly the same thing in three weeks. Unfortunately Danner wouldn’t warranty them. Last set I owned.
  13. Went out yesterday for a ride. It’ll probably be the last unless we get a good spring dump. Usually have to shovel down to the cabin door.
  14. We used to come to Haugan and sno cross race. We would run up and ride some of the trails where you were to test and tune.
  15. We are way short. We did get a couple of feet but that settled down a bunch.
  16. I would also like to ride your country. Really like the pictures
  17. It is great. We got lucky to be up there on Friday before the weekend rush. It has been real slow around here with no snow. There is a mining cabin one draw over, in 2017 we could ride over the roof and yesterday we could still look in the windows
  18. Got out yesterday. Still way short on snow but it was a gorgeous day in the sun. The mountain pictures was at around 9200ft. We just put a 165 on the black 2012 800. MDS clutching hit it spot on and it was an animal. Wish we had more snow to need the 165’s
  19. Unfortunately with everywhere so short of snow it’s going to get beaten. I’m about 3hrs from west and we don’t have much. Very avalanche up high. If anyone ever comes this way let me know and I’d gladly go and show some the places we ride. My youngest and I went for a very quick trail ride last night to see how the sleds were going to run. Probably won’t get to go anymore this weekend because we will be helping with the SkiJoring.
  20. If you come this way let me know and we’ll go find some
  21. Finally got to go the mountains yesterday. About 2’ of new snow. Only about a 1/3 of what was in the same spot last April. Hopefully it keeps coming.
  22. I appreciate the correction. I had been missed informed. Thank you
  23. I don’t know the reasoning in this application but with tires it’s because the pressure doesn’t change with temperature.
  24. Remember exactly where I was sitting. Will never forget.
  25. They both are Belgian. Her sister is also breed and is a little behind.
